Question about Electrolux Kitchen Ranges
On my stove all the red warning lights except one have fallen out of the fascia panel- just leaving a hole. The lights can be seen- still working- if you peer down the hole. But how to get them put back? Any answers?
    Guru:
  • 257 Answers
Hello Catherine 763,
I understand that you are having a problem with you indicator lights. The lights have came out of the clips that hold them in place. In order to fix this problem you will have to go in to the control panel. Follow the directions below:
1. Unplug the unit and remove if from the wall as you will need to get into the rear of the unit.
2. Remove the upper rear panel where the lights and switches are
3. Locate the lights and replace them to holes that are closes
4. Put the rear panel cover back on
5. Plug the unit back in
6. Put the unit back in its resting place
7. Use the unit as usual
If you need to replace any of the holders or lights post the make and model number and I will try and locate the cheapest suppler of the items you need.
Thank you for choosing FixYa.com
Justin
Posted on Apr 01, 2011
How do I remove the fascia from the control panel on my oven which has gone rusty
you don't give enough information stove make model, etc. or even if the fascia could be removed; most if can are "glued" down or some other means. Go to an appliance parts place with your stoves information and ask them..
Jul 01, 2015 | Kitchen Ranges
Element on indicator light for frigidaire electric stove fell out. How do I fix it?
I know what you are talking about. It is the little light on the panel and it comes on to warn you if the element on the top of the cooking stove is hot. There is a little plastic red piece that pushed in the hole. The light you see clamps onto it. You have to pull out the oven and remove the shiny metal back from the oven. Make sure you unplug or turn off your power to the oven. You will need to buy a new red plastic piece. It is called a light lens.
light lens here
Jan 02, 2012 | Frigidaire GSX 1100 E Kitchen Ranges
GAS TO STOVE WAS TURNED OFF FOR COST SAVINGS BECAUSE NOT USED. OVEN PILOT LIGHTS WON'T LIGHT CAN'T SEE WHERE HOLE FOR LIGHT IS SO TO BE CLEANED??IT LOOKS LIKE A BLEEDER VALVE FOR BRAKS IS HOLE AT...
To light those pitots remove oven floor& access panel below the doors,for each oven will be a gas valve inside of the panel below the doors and has a red button. push that red button,light pilot inside of oven near the main burner,hold red button for 30 seconds and releas.Pilot should be on,repeat for other oven. If pilots go out after red button was held down for 30 seconds the part called the thermocoupler will need to be replaced
Aug 18, 2011 | Garland H283 Gas Kitchen Range
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
How do you remove the air filter box on a 2001
REMOVAL
Release hood latch and open hood.
Access Rubber Grommet
Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
Fastener Locations
Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
Remove Push In Fasteners
Remove the push pins attaching the fascia to the upper radiator closure panel.
Headlamp Jack screws
Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
Roll Fascia Forward
Roll fascia forward to clear way for headlamp housing removal.
Disconnect wire connector from back of lamp socket(s) and/or bulbs.
Remove Headlamp Housing
INSTALLATION
CAUTION : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
Place headlamp housing into position.
Connect wire connector to lamp socket(s)
Verify headlamp and signal lamp operation.
Install jackscrews to attach headlamp housing to crossmember.
Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
Install nut on fascia stud through the splash shield access hole.
Verify headlamp operation and alignment
Nov 03, 2009 | 2001 Chrysler 300M
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Would like to switch off clock light, esp at night, or even permanently
Proceed at your own discretion, this will void your warranty. This worked with my Model 3 clock radio:
    1)Remove the four corner screws on the back panel with a long phillips screwdriver.
    2) Do not remove the two other screws on the back panel.
    3)Gently pull the front panel forward, sliding it out of the wooden case leaving the back panel in place. You can pull of the front panel just free of the case and lay it flat before the connected wires are taught.
    4)Unplug the 7 wire harness leading to the back of the clock.
    5)Separate the brown wire from between the black and red wires to make room to cut, or modify it.
    6)The brown wire is the lead wire to the LED light on the clock. To permanently disable the light, cut the brown wire. Better yet, install a switch in line with the brown wire, which I have not attempted yet and is not covered in this fixya.
    Good luck, I have always loved this radio except for the pesky light keeping me up at night.
May 28, 2009 | Tivoli Model Three Clock Radio
Oven will not heat
ok few things sound like the gas valve may be turned off what i mean about turned off is at the gas valve contro;l normally installed under the stove on the left side of the valve tere is a verry small lever that serve as a shut of vave i have seen those lever in plastic normally red it may have sticked it self close or fallen out check on the floor if you do not see any small parts another thing check for fuse also there is a solenoid valvve that possibly not opening up one more thing does your stove connect to a normall 120 volt plug or does is connect to your 220 volt electric stove plug with a adapter if so check your breakers thanks gilles_dumais@hotmail.com
Mar 15, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
We have a new maytag kitchen stove model merh865raw. We have had it about 2 weeks. Now the surface indicator light will not light up when in use.
If the indicator light you are referring to is the 'surface hot' light then either the element has failed or a connection to the element has fallen off.
If the indicator light you are referring to is the 'element on' light then either the corresponding control switch has failed or a connection to the switch has fallen off.
It may be possible the lamp has failed..although never have seen one fail yet.
Jun 08, 2008 | Kitchen Ranges
Kitchen Ranges Logo
82 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
