Question about Gateway Computers & Internet
Hi - I have a Gateway Laptop Computer NV78 and when I turned it on this evening the mouse was forzen, I turned the computer off a few times using the power button but each time I restarted it the mouse remains forzen in the center of the screen
    Guru:
  • 433 Answers
Key board or mouse not work mean one of four reasons
1- kb or mose is damaged (replce it )
2- ps2 socket is damaged (can be replaced )
3- Resistance No 472 on motherboard is damaged (can be replaced )
4- I/O IC is damaged (i think no repair )
easy solution you can buy a (usb-ps2) converter
best regardes
Hi -
Posted on Apr 01, 2011
Where does the rj-11 cable attach to the motherboard on a gatewat nv78
Hi Tammy,
the RJ11 would connect to the Modem port on the right side of the laptop located beside the DVD Drive,
attached below is the link to the description and manual
http://www.manualowl.com/m/Gateway%20Computers/NV-78/Manual/147468?page=6
hope this helps
warm regards
Apr 19, 2014 | Gateway Computers & Internet
Wired mouse sometimes lights up but even when it does it does not work pointer
These optical mouse do not work on a shiny surface. Try using it with a mouse pad or place the mouse on a piece of paper.
Nov 27, 2012 | Gateway USB Optical Mouse MOAKUO 7010867R...
Gateway microphone drivers
You can download the device drivers for your model Gateway laptop from this WEB site. Make sure you select your model laptop and the correct Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Oct 14, 2012 | Gateway Computers & Internet
Gateway NV78 laptop turned off and won't reboot.
So reformat a computer that can't access the hard drive, interesting trick. I believe the OP said the machine hangs in limbo with Power Lights on, I assumed the Lights are on, but no one is home, sort of like some of these solutions. Why am I not paid millions of dollars for being the smartest man alive?
Aug 12, 2012 | Gateway Computers & Internet
I have a Gateway NV78. When the battery dies I charge it using the power supply. After it is fully charged, the computer will run strictly off of the battery. If I leave it plugged in, the battery will...
This is a case of how much you want to spend. The battery could be the problem or the motherboard, batteries are about 50 and motherboard are 3 or 4 times that much,
Apr 07, 2017 | Computers & Internet
Have a Gateway NV78 Laptop love it but there are 2 blue lights on lower left corner of the laptop and the one on the right goes to "red" sometimes why? This is "on the case" not the screen/monitor...
Do you have the Gateway NV78 Series User's Reference Guide?
(English)
Gateway Support > NV78 Gateway NV78 Notebook Series > Support Documents,
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78ul.shtml
If not, left-click on,
Gateway NV78 Series User's Reference Guide - English
This is a PDF file.
Takes a few seconds before you see the first page, and additional time to fully download.
Suggestion is that you let the file fully download, before looking through it.
(Your computer has Adobe Reader on it, which uses PDF files)
Page 18,
Battery Charge Indicator.
(Has a symbol which looks like a flashlight battery)
"LED Solid Red
Battery is malfunctioning
Important: This LED only lights up when your notebook is connected to AC power, (The AC adapter is plugged in. 'Charger'),
or the battery charge is very low"
Jul 03, 2010 | Computers & Internet
Gateway laptop mouse not responding
In the rows above your Function keys (F1-F12) you should see some icons above F7-F12 (these are capacitive touch keys). If you see one with a square with a hand pointing with a plus sign, and it's red, just touch it. It's a touch key to disable your touchpad.
Nov 01, 2009 | Gateway Computers & Internet
I have a Gateway laptop MX8738, Windows Vista, Dual core. My issue. I always plug my computer into outlet. Do my work. Close down laptop, and unplug from wall. Then about 3 hrs later I plugged in laptop,...
Hi there.
Take the battery out and try to boot on AC power only, if it boots up, turn it back off and reinsert the battery and try to boot again.
If it still suffers from the same symptoms please post back for more advice.
Good luck
Jun 15, 2009 | Gateway MX8738 Notebook
Gateway Notebook T-6330-u Mouse Problems
Many laptop touchpad issues can be fixed by updating the laptop touchpad driver. See if you can plug an external mouse into the laptop and then use that mouse to to to the gateway webpage and see if you can get the updated driver for you model laptop.
Dec 27, 2008 | Gateway MT3705 Notebook
Cordless mouse and most other usb connectors
hi friend ,
i will tell you the few steps to install your mouse.
  1. first un plug the usb mouse adapter from the cpu and restart the computer.
  2. after enter into the windows now put the adapter into the usb adapter.
  3. if computer ask any driver to install for the mouse.
  4. if you have any usb mouse or ps/2 mouse please connect it to the port into the computer then use both mouse at the same time.
  5. when you are using both the mouse just scorll the mouse both the mouse to check it. that the mouse will correctly
  6. if computer ask the driver then after connect the ps/2 then put the driver cd inside to the cd drive and install.
  7. after install the driver software then you can use both mouse at the same time.
try it , if prob comes again tell me
bye.
May 14, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
127 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
