Question about Acer TravelMate 2480 PC Notebook
Hi, how can I reset my erecovery password? - Acer TravelMate 2480 PC Notebook
    Scholar:
  • 67 Answers
If you have lost Acer laptop password, the best thing for you is creating a password reset disk.Actually,when you add a password to your pc,the first thing you should do is creating a disk in case you lost the password.But how to make a password reset disk after you have lost the password ? Follow these
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Key
Then let's begin
Step 1.Login to a PC which can link to internet,Download and install the program from http://download.cnet.com/Windows-Password-Key/3000-2092_4-75031111.html in that PC
Step 2.Run the program and burn to CD/DVD OR USB flash drive
Step 3.Turn to your locked PC,insert the newly create CD or USB to your drive.Reboot the Computer and then follow the instructions,it is very easy to use.
Posted on Apr 01, 2011
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
***This will erase all your unsaved data!***
Or
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Or
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
Tip
How to Reset an Password for Acer eRecovery
Acer eRecovery is a vendor-specific method you can use to restore your computer to its original factory settings, or to custom settings you create and store on your hard drive or other removable media. eRecovery also contains a back-up utility you can use to back up data to your hard drive or other removable media. Access to eRecovery requires you to use the default "000000"password or one you select. While it is important to store a custom password in a safe location, if you lose or forget it, there are steps you can take to reset your Acer eRecovery password.
Access the Diskpart command prompt. Acer stores custom eRecovery passwords on your computer in PQService, a hidden rescue partition. Locating this partition requires accessing the Diskpart utility from the command prompt. Diskpart allows you to run a scan on your hard drive and bring up hidden partitions.
02d2ca3.pngstep 1. To access Diskpart, go to "Start" and type "cmd" in the Search bar to bring up the black command prompt box, and then type "diskpart" at the prompt to switch to a Diskpart prompt. Depending on your computer, a new command prompt may open with the Diskpart prompt.
Step 2. Scan your computer configuration. At the Diskpart prompt, type "rescan" to run a system configuration check. When the scan finishes, you will receive a message informing you the scan is complete. At the command prompt, type "list disks" to bring up available disks and then type "select disk 0."
Step 3. Locate the hidden partition. At the command prompt, type "list partition" to view a list of partitions on your disk. Locate the partition with no name and a size of approximately 10 GB. At the command prompt, type "select partition (number)."
Step 4. Determine the partition type and unhide the partition. The hidden PQService partition will be either a type 27 or a type 12 partition. If the partition is type 27, unhide it by typing "set id=07 override," and if a type 12, then unhide it by typing "set id=0B" at the command prompt.
Step 5. View PQService partition. Return to the disk containing PQService by typing "select disk 0" at the command prompt, and then type "list volume" to view the contents of the disk. PQService will be visible in the list, preceded by a number. Type "select volume (number)" and then assign PQService a new drive letter so you will be able to open and view it from your computer interface window. At the command prompt, type "assign letter=f."
Reset eRecovery Password
Step 1. Open PQService. Navigate to the drive containing PQService. If you are using Windows XP, use My Computer; if you are using windows Vista, use Computer. Find the file "aimdrs.dat." Right click on the file and select "Open with" and then "Textpad," "Notepad," or whatever text editor you prefer.
Step 2. Open file and find password. Open the file with your text editor and locate the eRecovery password. Look for a line that reads, "Password=password name," "Hint=the password hint." Write down the password and close the file.
Step 3. Open eRecovery using the recovered password and follow instructions to create a new password.
Partner: Windows Password Recovery Tool
Contact:annyyu22@gmail.com
Blog:http://www.blog.lostwindowspassword.com
on May 18, 2010 | Computers & Internet
F10+alt don't work to reset acer aspire one to factory setting. what else can i do
Hi twillis84.
You will need to start your computer in the "Safe Mode", you do this by tapping F8 while the computer is starting up.
Once the computer has started, select "Safe Mode" you have two choices.
I would try "A" first.
A...You can do a System Restore from here.
You will click "Start">All Programs>Accessories>System Tools>System Restore, this will restore your system to an earlier time when it was operating properly.
B...Once you are in the safe mode, then you will double left click on "Start">Control Panel>User Accounts>Change an Account.
Now you can change your password,delete the account,etc.
Driver restore/applications Acer---using eRecovery
Drivers for Acer products may be found on the Acer Product Support. Search for the product and download the drivers.
Alternatively, the factory installed drivers and applications can be re-installed by using Acer eRecovery by following these steps:
1.Click Start, and then All Programs
2.Click Acer, and then Acer eRecovery Management
3.You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
4.In the next window on the left toolbar, select Restore.
5.Choose Reinstall Drivers or Applications
6.Choose Contents
7.Choose the driver or application you wish to install
8.On the right, click the Install link and follow the prompts.
9.The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
If you do not have a set of Acer Recovery Media, they may be purchased from the Acer Recovery Media Order Form.
Acer Website:
http://support.acer.com/us/en/default.aspx
Please take time to rate me
Bud
Sep 24, 2012 | Acer Aspire One AOA150-1949 Laptop
How to factory rest a acer travelmate 2410
Acer eRecovery stores pre-loaded software internally for easy driver and
application re-installation.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery window, select Recovery actions and click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
At first launch, Acer eRecovery prepares all the needed software and may take
few seconds to bring up the software content window.
Mar 22, 2012 | Acer TravelMate 2300 Notebook
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer 3630 has its own erecovery system to reset the computer to its default state. The erecovery password is 000000 BUT I CHANGED THE PASSWORD :-( I can't work out what it is, I've forgotten, and...
A virus shouldn't be eating space on your hard drive. If anything, a program might not be properly deleting temporary files when running. If you cant remember the password, you can try to find a restore iso on the internet that would suffice. Acer may even offer replacement discs which will have the same purpose.
Dec 29, 2009 | Acer Computers & Internet
Acer e-lock locked my cd-rom
Acer eRecovery Management and Acer disk-to-disk recovery are protected by a password that can be changed by the user. Follow the steps below to change the password in Acer eRecovery Management.
Boot to Windows XP.
Press ALT + F10 to open the Acer eRecovery Management utility.
In the Acer eRecovery Management window, select Recovery settings and click Next.
In the Recovery settings window, select Password: Change Acer eRecovery Management password and click Next.
Follow the instructions on screen to complete the process.
Sep 01, 2009 | Acer Aspire 3000 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
2 Press Alt + F10 to open the Acer eRecovery Management utility.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
I want to reset my laptop back to original factory shipped settings.it a travel mate 4200
Follow the steps in the users manual for eRecovery manager.
Page 47, I believe, gives details.
Re-install bundled software without CD
Acer eRecovery Management stores pre-loaded software internally for easy
driver and application re-installation.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
click Next.
click Next.
to re-install.
At first launch, Acer eRecovery Management prepares all the needed software
and may take few seconds to bring up the software content window.
Apr 07, 2008 | Computers & Internet
Acer TravelMate 2480 PC Notebook Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
