I bought a peavey 1200 power mixer, but there are no instructions. Can you help
  • 752 Answers
It can be downloaded here:
http://peavey.com/support%5Csearchmanuals%5Clist%5Cama1200.cfm
please mark as solved.
Posted on Aug 05, 2008
How do i record using the 1220 peavey mixer
hi, look here http://www.manualslib.com/manual/121133/Peavey-Xr-1220.html
Dec 06, 2014 | Peavey XR 1220 Powered Mixer 20-Ch Powered...
How do i set up a Peavey xr560 mixer and graphic equalizer
PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
Oct 12, 2014 | Peavey Audio Players & Recorders
How to eliminate hum noise on Peavey XR122D 1200 watt powered mixer
Sounds like a ground loop. Is the noise present with NO inputs?? Or?
Jul 21, 2014 | Peavey Audio Players & Recorders
Hooking up other external systems
Peavey XR 1212 You may find helpful info from the Peavey site. I'm not sure how you want to configure your setup, but the tape out may be able to feed the power amp.
Mar 24, 2014 | Peavey XR1212 12 Channel Powered Mixer
Mixer recognizes input and lights show it but no sound is coming out, Ive tried several speakers and cords but nothing.
I am assuming this is a new unit. Take a 9V battery and momentarily connect it across the speaker wire, it must not be connected to the amp. If it makes a noise that indicates that the speaker is probably OK, if not you found your problem. You may want to take to the store where you bought it for help. Check: http://assets.peavey.com/%5Cliterature%5Cmanuals/116558_26336.pdf You can download the manual.
Mar 07, 2014 | Peavey PVi 6500 Powered Mixer
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
I have 110v XR 1220 power mixer and friend of mine plug into 240v power point, blown the two transistors ou. I do not know what short of transistors are they?
There are dozens of transistors in the unit... we can't guess which you might be refering to. The power supply of the 1200 series mixers have fuse before each part of the supply for the preamp sections.
Jul 13, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I have just bought a peavey xr800f powered mixer but unable to get echo on mics any help would be appreciated thanks
There are SEVERAL things to set. First is setting the EFX mix for those channels you want the effects to be active. Next, select the effect you want AND the TIME for the effect and FINALLY the amount of the effect output to go to the MAIN and MONITOR outputs. Also the effect disable button below the effects needs to be in the correct state. ALL of these have to be set for using the effects on the mics.
Feb 07, 2011 | Peavey XR 8600D Powered Mixer
132 people viewed this question
 Grubhead
Grubhead
