Question about Dirt Devil Vacuums
Dirt Devil 086905 has suction through hose, but will not **** at the power floor head. Cannot find a clog, brush spins. What should I be checking?
  • 731 Answers
Need to take the head apatr as if you were replacing a belt. Look for the clog... it's there
Posted on Apr 01, 2011
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Jul 10, 2014 | Dirt Devil Vacuums
I have a Dirt Devil Jaguar bagless vacuum. It used to work great. Now, it is blowing a huge amount of dust out of the front of the machine as I try to vacuum the carpet. can this be remedied?
This generally happens if the hose system is clogged. No suction so the power head brush just kicks out the dirt and debris you're trying to pick up, and loose stuff that is currently in the hose system. If it has been doing this for quite a while, or has been used with blockage, the motor has to work harder and will eventually burn out, if there is no overheat shut of switch in the cleaner.
Check all parts of the hose system, from the power head to the tank. Clear all clogs. That should take care of the problem.
Another possibility is that the fan blades are broken or worn down. This would result in no suction even though the motor is running.
Dec 09, 2010 | Dirt Devil Vacuums
Low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
"brush bar spins erratically"
Belt needs to be replaced, it has stretched to the point that under load, it won't turn the brush roll like it should, so I would advise replacing the belt. And while you are doing that, check the brush roll and make sure the ends turn freely, if not, then replace it also. Then check the dirt inlet while you have the brush roll out.
Feb 29, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Poor suction
Check the inlet down by the brush roll, make sure it is open, if it is then the hose itself must have a clog. If the hose comes off, drop something like a marble in one end and see it it comes out the other end, if it doesn't then you have a clog.
Jan 10, 2008 | Dirt Devil M1100009 Reaction Soft Touch...
Vacuums Logo
716 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
