Question about Garden
How to tune the carberater - Garden
    Top Expert:
  • Garden Master
  • 80,417 Answers
On what make and model number?
Posted on Apr 01, 2011
Why does my craftsman riding mower choke itself off when too hot
Clean the carberater the carberater is the number one problem for craftmen lawnmowers pay close attention to where the springs are hooked there are several holes the spring can go in take it apart slow and clean every littel hole and put it back together take your time dont get in a hurry its not to hard just time consuming then anythaing sholdent take a newbie more than 2 or 3 hours max me half an houre
Aug 18, 2014 | Craftsman Garden
I have a ram 50 1985. the choke will not open on the carberater. what could be the problem
There should be a vac device called a pull-off that opens the plate about 20% when the engine starts. Then the electric coil heats up to open the plate in a few minutes of run time.
Sep 08, 2012 | Cars & Trucks
What or how to adjust the carberater
I take it you just found a heading for your saw and it is gas operated, not electric? Adjusting the carb, you have 2 jets on the side , one low one high, depending on what it does, won't rev, won't idle, open up the adj screws 1/4 turn and see what happens, if they have been moved in and out and are way off, turn them all the way in and then out 1 1/2 turns each, this should get you running. You can fine tune from here, one at a time, and very fine adj. It doesn't take much. make sure the gas is mixed right, and the chain does not bind. Hope this helps.
Aug 16, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I need a diagram to rebuild a 1970 Jeep CJ5 225 Slant 6 Carberater
these are not difficult to rebuild, the diagrams comes with the rebuild kit, just make sure you clean all the parts thoroughly,
Dec 04, 2009 | 1993 Jeep Grand Cherokee
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 22, 2009 | Briggs & Stratton Garden
GASOLINE OVER FLOWS IN THE CARBERATER AND DOWN THE CRANK CASE.
the float in the carb. is probably sticking open and will have to be cleaned . Try tapping the carb and see if this will get it unstuck. hope this helps you
Oct 26, 2009 | Garden
The carberater is leakin gas
hi mate you float is to high in the carb take the carb off and take the bottom casing off and adjust the float to the correct measurements in the manual if the float is too high it is allowing to much fuel in and so it will flow over the over flow and out the tubes it is simple puch the pin out and adjust the metal where the little valve is hanging onto with a pair of long nose pliers good luck
Jul 07, 2009 | 2003 Suzuki RM 250
Snowmobile yamaha enticer manual for carberater
why don't you just check the compression if it's low fix it check the carbs make sure it works and make sure you bearing are goo your clutch your vbelt your track and that you have a the boggy wheels on it
Jan 11, 2009 | Yamaha YHT-340 System
POWER TOOLS CHAIN SAWS
Maybe it has a bad reed valve, check it.
Nov 15, 2008 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
