Question about Cub Cadet Garden
WILL OIL ESCAPE A LEAKING BREATHER GASKET GT2523-54 13A-2A8K710
  • 1,511 Answers
It very well could do that
Posted on May 09, 2014
Egr valve chevy lumina '97 3.1 lumina ,i pulled the egr there was a white greasey substance in it as well as well as the passages to the throttle body and and exhaust, what is it,where did it come...
that sounds as if your engine breather system requires cleaning, the substance is emulsified oil, normally caused by poor oil, lack of oil changes, or possibly head gasket problems, clean out all the breather hoses, filter etc, run engine until warm, drain engine oil and refill with a good quality oil, renew oil filter and then run and check again after a few miles
Oct 27, 2013 | Cars & Trucks
Oil leaking out of air filter
First check manifold breather . when you take carb off theres a lil hose that connects to the breather on the side of the motor . Replace it. If it still doesnt work check level of oil if its overfilled that could be your problem. If that doesnt work pull the head off look for a blowed spot in your gasket . If it is it will pressurize your motor pushing oil out of your carb.
Sep 16, 2012 | Garden
Oil cap and dipstick covered in creamy sludge, is this breather prob as not losing any water
Yes, it could be that a plugged up Positive Crankcase Ventilation (PCV) valve or engine crankcase breather (with filter) is the cause allowing moisture to condense in the crankcase. However, if the valve and breather are okay, a cylinder compression test should be done to verify that the cylinder head gasket is not leaking. Regardless, the engine oil should be drained and the engine flushed with clean oil and an appropriate crankcase flush additive. Entrained water in the oil (the creamy sludge) will damage engine bearings quickly.
Mar 05, 2011 | Volkswagen Golf Cars & Trucks
What could be the causes of oil pumping from crankcase tube to carb b/s 14 hp... other than broken oil ring??
worn compression rings , & oil control rings
worn bore ,
worn ring grooves -
loss of crankcase vaccumm , - c/case gasket broken/leaking
stuck breather ,
high oil level
blown head gasket ,
check simple things 1st
Aug 08, 2010 | Briggs & Stratton Garden
I had a transmission replaced on a 2005 Ford Escape. Within 1 month the front axle seal started leaking. Could the seal have been damaged during the tranmission replacement, or by over servicing the...
try seeing if the breather is blocked on top of the axel.if this is blocked.the pressure will force the oil out the most easy way.usually the oil seal
Apr 05, 2010 | 2005 Ford Escape
1979 briggs and stratton 11 hp how to fix
If it is, as you say, a 1979 or so engine, the crankcase breather could have well worn out. This will cause the oil burning and blowby. Replace the breather as an assembly, they are cheap and available from any Briggs dealer. The leaks are probably loose bolts and/or bad gaskets. You will just have to figure where the leaks are and replace the appropriate gasket. The breather could also cause the leaks so do the breather first then run it for a while to see if it is still leaking
Sep 20, 2009 | Garden
Oil spray onto underside of cat...v70 2.4 turbo AWD. Possibly turbo oil return pipe, oil seperator is part of block........not the external black one.
there is a seal on t hr breather box that could be leaking if there is oil across the oil pan if it is only on underside of car then the turbo return is leaking that is most common probably 10 dollars for gasket and seal and easy to change
Aug 18, 2009 | 1998 Volvo V70
Leaking tranmission shaft seal
Hi there. I’m not exactly clear which transmission seal you are referring to, but no matter, the first thing I’d check-out is the breather system on the transmission. Every transmission builds-up pressure when being driven and if the breather is blocked; the internal pressure within the transmission is strong enough to force oil out the weakest areas – that of course being shaft seals. So firstly check out the breather system to ensure it’s not blocked, it might save you having to replace a seal unnecessarily. Hope this help, Scottech
Jul 01, 2009 | 2003 Ford Escape
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
