Question about Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA)
Boot up problems
Hello:
I have a compaq presario sr 1810nx that will not boot. It gets to the compaq screen and freezes.The keyboard does not work. Here is a list of things I've tried.
  1. Reseated ram
  2. Checked IDE cable connections
  3. Switched power supply
  4. Switched keyboard
  5. Called cust support
  6. Replaced processor
  7. Used recovery disks-No response
  • 4 more comments
  • twin688 Aug 05, 2008
    Crabbypup:
    Computer repair guy tested, but I'm not sure how as far as a testbed. He said it had to be either cpu or mobo. I figured I'd start by replacing the cpu. As far as drives being strapped properly, everything appeared to good as far as I could tell.
    Coss71:
    It's been down for so long I can't remember if any new programs were installed but I don't think there were. I can't get it to boot in safe mode because it won't go past the compaq splash screen. Pressing any of the keyboard key gets no response. There also are no bios beeps, but on this comp I don't remember ever hearing any on startup.
    Coss71:
    Thanks for your response. I disconnected all drives, ram, and cards then powered on. I did get one long beep followed by a pause, and a long beep again. Now that you mention the fan, I did notice something different. As part of trouble shooting I reset the bois by switching the jumpers on the mobo (per compaq website). After doing this I noticed the fan was a lot quieter and seemed to be spinning at normal speed. So I guess you could say it did sound like a small jet before resetting the bios. What next...?
    Thanks
  • curvaclub Dec 08, 2008
    hey i tryes upgradinng my ram it wasnt in the slot good and it smelled like something was burning so i shut it down pout the memmr in good and now just keeps having long beep but doesnt boot up?
  • crabbypup May 11, 2010
    are all your drives strapped properly? maybe the board is no good. have someone put it on a testbed and see if it will boot that way.
  • Coss May 11, 2010
    Can you get it to boot to Safe Mode?
    Have there been any new programs installed just before this happened?
    Have you tried booting to "Last known good configuration"?
    Genius:
  • 1,056 Answers
If it won't go past the splash screen, and you have replaced the CPU, I agree that it is probably the motherboard.
One other test you can do is, remove the memory chips, and any cards that are plugged it, and see if it beeps on start up.
If it does, count the beeps. If it doesn't it is the motherboard.
If you get beeps, plug the memory back in, and try again. Listen for beeps. Let us know what you find.
And I don't know if Compaq's do this (Dells do) when you turn it on, do the fans spin up normally? Or does it sound like a small jet? Speaking of which, do you see the fans spin up at all?
Posted on Aug 05, 2008
  • Coss Aug 05, 2008
    Replace the motherboard.
SOURCE:
Desktop won't boot up
it has to be your hardware problem must be your keyboard connection or hard disk failure
Jul 15, 2010 | Compaq Presario 5000 PC Desktop
Computer keeps freezing, will not control alt delete. Have to shut down manually, but only to freeze again.
sounds like you have a virus boot your pc in safe mode to do this press f8 on your keyboard after the first startup screen you should get a screen up with boot options choose safe mode let your computer start up then run your antivirus program when finished reboot computer hopefully this will solve your problem
Jul 14, 2010 | Compaq Presario SR1000T (568657) PC...
Can't access laptop computer in safe mode, keyboard freeze up
Try booting your system from a LIVE cd like linux, a verson of Hiren's tools, or the UBCD (ultimate boot disc for windows). If your keyboard still freezes with the alternate OS, you may have a hardware malfunction.
Jan 18, 2010 | Compaq Computers & Internet
Turn the computer on no matter which button i push
You may have a defective keyboard. A defective keyboard will stop the boot up process. Try another keyboard and see if that fixes your problem.
Oct 09, 2009 | Computers & Internet
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Need system disc
check the drive assignments in the Bios at boot up harddrive first. If there is no system on it then getting a disk with a system will only bring you to anouter awakening.
installation of a system is needed
Jul 29, 2009 | HP Compaq Presario SR1303wm PC Desktop
Hi, when i boot my Compaq Pressario 700ap i get a DOS screen the bottom line being that there is an "0211: Keyboard Error". I then have the option of using the 'F1' key to continue with the boot or 'F10'...
First, I would go into the BIOS by pressing the F10 or F2 key during boot. Then look on the BIOS screen for 'keyboard' and see if it is recognized in the BIOS.If it says "not present" then you need to ttoggle the TAB key or SPACEBAR to set the BIOS to recognize the keyboard.
There are other causes for your problem,but try this first.
Apr 12, 2009 | HP Compaq Presario 700, 700A, 700AP,...
Compaq presario 2500 does not boot
you got an OS problem try to re install your OS.
Oct 17, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Access BIOS
on compaqs the first screen usually will allow you to choose a boot device by pressing f11 you should then be able select the boot device.
this a black screen with icons at the bottom representing hdd floppy CD and network boot you move the cursor to select the appropriate boot device
Oct 17, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA) Logo
284 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
