Question about Welding Tools
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
  • 407 Answers
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Posted on Apr 02, 2011
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
I have a 12vs x-treme when I pull the trigger I get a slight hesitation in wire feed with soft start off is this normal? Never had that problem with my older 12vs or12rc
If by hesitation you actually mean a delay, it may simply be the bypass of the soft start feature needs to charge to a certain point for it to maintain a constant feed rate and that is what you are seeing. If it has been consistent from day 1, I would not worry too much about it.
If it is an annoyance, a board swap might resolve it. Miller does not show that model nor the others so I am not able to look at how each one's control board is wired into the welder specifically to advise further.
Dec 22, 2011 | Miller Welding Tools
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Welding Tools Logo
214 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
