Question about Kenmore Refrigerators
Not cold enough-turning up dial does not help.
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
Do I just plug it in or do I need to turn dials
if the dial is on 0 then it needs turned plug in and set dial to the middle of range . like 4 or 5 let the unit get cold and see if it is cold enough . it not turn up some more .
Feb 19, 2016 | Refrigerators
Freezer and refrigerator not cold enough
maybe turning the temperature dials up will help
Aug 15, 2015 | Refrigerators
My fridge not cold enough
If you have turned the dial up as high as it can go "9" and it still is not cold enough, you will need to have some freon added. There is not to much to a fridge. Best of luck.
Dec 21, 2014 | Frigidaire FRC150FF Frost Free Fridge...
The fridge doesnt seem to be cold enough not sure which way to turn the dial no indication as to which way to turn. No instruction manual to refer to.
Make sure the freezer dial is in the middle (12 O'clock) position if it has one
If it is turned too far towards the right it will cut off all air flow to the refrigerator
compartment, the air flow from the freezer cools the lower compartment. Also make sure
the fan is running, if it has failed then the freezer will freeze up and block all air flow.
The refrigerator compartment has a cold control as well, it is normally turned toward
the right to make it colder or if it has numbers, set to 5 or above.
I recommend setting the refrigerator to 36 to 39 degrees (just above freezing). using a
thermometer (stick type set in a cup of water overnight to get an accurate reading).
It is the preferred method, and will help in this instance since the numbers aren't legible.
Hope this helps.
Mar 12, 2011 | Hotpoint Refrigerators
Hi my lower part nolonger gets cold enough to keep fresh foods yet the freezer is working well
Set dials to middle setttings, if the colder /warmer dial is peffed max cold its max cold freezer!!! so move to warmer and the freezer will give more airflow to the reefer , the reefer is reliant upon the freezer for its cold air.
Nov 01, 2010 | Magic Chef CTB1821AR Top Freezer...
Freezer works fine but fridge portion is not getting cold enough
by any chance do you hear the fan on at all........reach into the top freezer and feel if any air is blowin out of the vents..........if no air blowin it might just be the fan motor......it might be defective........................more details would be good..................
Jun 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
Freezer is not cold enough.
Turning it to the right will make it colder. It will only regulate the temp. by few degrees, so if your thinking there will be a big change there won't be.
Jul 31, 2009 | Viking Freezers
Dial not turning
in process of dial removal, the dial was somehow jarred to cause some disassembly of the dial...look at the dial body clasps carefully
May 22, 2007 | Whirlpool AWM5104/1 Front Load Washer
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
