Question about TechnoMarine Cruise Watch
The seconds hand of my watch ticks but the other two hands dont move at all. I have a technomarine cruise sport watch.
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Posted on Oct 20, 2007
SOURCE: Tag watch second hand skips
Yes it's the battery. Please make sure to take it to someone QUALIFIED This watch requires that all the gaskets be replaced and pressure tested at the time you have the battery replaced
Donald McPherson
www.finewatchmaking.com
Posted on Dec 01, 2007
indays
  • 111 Answers
SOURCE: Bijoux Terner Sport Watch Trouble
just press the setting button and select the normal time
Posted on Aug 25, 2008
escapement
  • 2334 Answers
SOURCE: Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Posted on Mar 22, 2009
escapement
  • 2334 Answers
SOURCE: I reset the date and now the second hand ticks at
This is END OF BATTERY LIFE warning. Replace the battery and everything will be fine. Rate me plz.
Posted on Mar 05, 2010
HOW TO RESET STOP WATCH TO ZERO
What you need to do is to pull the crown to step 2 (full out) and then push the start button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero.then push crown back in, That's it.
Feb 18, 2014 | Giorgio Armani Emporio Armani Sport Ar0532...
Second hand does not go to 12 when pulled out. I just had new battery put in and now the second hand goes to between 6-7 and on the 8 on two watches
I had the same problem. I pulled the crown to the 3rd position, furthest out, and pressed the A and B button simultaneously. The second hand made a complete rotation and set at the 8 position, where it had been settting, then I was able to push the A button and reset the second hand to the 12 position. Tested it and it is working fine.
Nov 04, 2013 | TechnoMarine Cruise Watch
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
May 12, 2009 | Tag Heuer Automatic Chronograph Series...
Rate me, please.
Mar 22, 2009 | TechnoMarine Ceramique Watch TCB02C
My watch is still working but the seconds hand has stopped
will just go to a technomarine service center to have my watches fixed.....
Sep 26, 2008 | TechnoMarine DTC55C (Size: Unisex Adult)...
Technomarine original limited pink croc watch chrono stopped working... second hand fell off and is loose inside the casing. where do i send for repair???? or is it not worth fixing and should i purchase...
You can take it to a reputable watchmaker (NOT a jeweler) and they should have no problem helping you with this problem. It might be that your watch isn't working because the second hand is stopping it from running. Have them CHECK your battery (opposed to just changing the battery) I bet the second hand is the reason your watch isn't working. If you have problems findind help PLEASE let me know, and I will be gald to assist you fher!
Sep 15, 2008 | TechnoMarine Watches
Technomarine
Sounds like the main drive is not "engaged" or you are in "stop watch" mode. Check to make sure you are in the correct mode. Then check to see if you can change the hour/minute hands. Reset the time and re-engage. See if that corrects the problem. (You've probably have done this already)
The watch has a 2 year warentee plus because it's water resistant down to 330 feet, I would take it back or to an authorized dealer to have it repaired. Other wise you stand the chance of damaging as really nice watch. And while you are there have them explain all the features. Really is a nice watch.
Nov 18, 2007 | TechnoMarine RSQC11 Wrist Watch
Watch
if it is an automatic you will have to wear it or shake it for a little while. If it is quartz then the battery might have to be changed.
Mar 29, 2007 | TechnoMarine Dial Chronograph Watch
TechnoMarine Cruise Watch Logo
89 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
