Question about Atd Tools (ATD31166) 38" x 50 ft Retractable Air Hose Reel 31166
How do i get to the ratchet on a ATD-31156 hose reel to repair it?
How to repair leaking inlet connection on the reel inside a yardworks retractable hose reel
sadly there is no repair parts for these pitch it and buy a new one all we can do .
Nov 23, 2015 | Garden
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Fishing reel wont engage
Sounds like it needs some TLC and repair. Home
I've included a link to The Reel People. MIke can help you out.
Nov 12, 2014 | Fishing
Can the hose in the retractable carrier be replaced? How do I do it?
You can replace that hose by fully extending it and locking the reel. At that point you should be able to unscrew the hose from its connector. A replacement hose can be screwed on in its place.
One alternative, if the reel's hose connector isn't inside the spool area, would be to just cut off the hose at the break, then buy a replacement hose end (with barb fitting to match your hose) and a small stainless-steel hose clamp. They work really well when you get one that's correctly sized for your hose. They're hazardous out at the "business end" of the hose, though - they can cut your hands.
Aug 04, 2014 | Toolshopusa Retractable 25' Air Hose
Rankam
You can get 10" never flat tires with 5/8" hubs that will work. Home Depot has 4 for $59 online.
May 12, 2014 | Ames 225ft. ReelEasy Hose Reel Cart...
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
Got longer hose how do i adjust the spring
Reel are made for a size 25' 50' Etc. what you want to put 30' on a 25' REEL.?.
Jan 15, 2011 | Toolshopusa Retractable 25' Air Hose
Craftsman 3/8 in. x 50 ft. Air Hose Reel, Retractable how to replace hose
Unreel the hose all the way out. Unscrew brass fitting at reel. Screw on new hose with fitting tape. reel up new hose. You're done. Good luck.
Jan 07, 2011 | Suncast Air Hose Reel GCWAR50R
Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Atd Tools (ATD31166) 38" x 50 ft Retractable Air Hose Reel  31166 Logo
167 people viewed this question
Top Atd Tools Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Atd Tools Air Tool and Compressor Expert? Answer questions, earn points and help others
