I am trying to hook my son's Playstation 2 to my computer moniter, and it's plugged into the back and all I get is the regular computer screen. I hear the noice of the playstation on the monitor though because it has built in speaks. How do I get the playstaion's video on the monitor?
    Problem Solver:
  • 15 Answers
Most monitors only have VGA or DVI inputs. the PS2 uses either a composite or a component connector. while the audio cables may be able to be connected fine, it generally isn't feasible to be able to connect the video without a conversion.
If there actually is a connector on the monitor, it may be as simple as switching inputs. there is usually an option on the front panel to switch sources if there are multiple inputs.
hope that helps :)
Posted on Apr 01, 2011
I WANT TO USE MY DESKTOP TO PLAY FILMS ON MY TV . DONE THE CONNECTIONS AND GOT THE RIGHT SCREEN WHEN THE COMPUTER STARTED UP THEN IT WENT BLANK SO I CHANGED THE RESERLUTIONS ON A MONITER SCREEN THEN...
What you should try at this point is shut everything down, Unplug your desktop, hook it back up to tour moniter and boot. If you now get a picture, go to your device manger and click on display adaptors. If you have more than one selection. choose your monitor. Let me know if this works.
Mar 11, 2011 | Computers & Internet
How to put playstation where it will show on a regular TV that does not have HD my son took his playstation over his friends who had a HD TV when he brought it back home and hooked it on same TV they had...
With the ps3 already on standby, hold the standby button with the television on the correct channel until the display shows, it will take quite some time. Then change your setup accordingly.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
No sound..
first make sure that your monitor has all of the drivers and speakers built into it.and that you have a a good audio cable.know that you have to have it in the audio port with the green around it(the middle one)you can't take regular speaker and plug them into the monitor.but you can plug them into the green port in the middle.also make sure that your other speaker are good.if you got any more questions email me at gamecrazy944@yahoo.com
Jun 29, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
Playstation 2 slimline
Hi Crazymatt,
You need to connect to the Cablemodem or have a router that will allow connection for both your PS2 and your computer. Connecting to your computer does not allow a path to the internet for your PS2.
Oct 31, 2007 | Sony PlayStation 2 Slimline Console
Connect Playstation 2 to computer monitor
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila. PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable. I hope this works for you-BCA
Aug 26, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
David Payne
David Payne
