Question about Kitchen Ranges
I have a rheem warrior glass water heater serial no rh1199629294 model no 71-308 i need to know where the reset button is please?
  • 396 Answers
You should have an access plate on top and at bottom. Before removing the covers, turn off the breaker that controls the water heater. Now unscrew the top cover. There may be some insulation covering the thermostat (the control that shows the temperature to heat the water to). Move any insulation out of the way and you should see a red button on the front of the thermostat. Press the button. You may feel a click, you may not. Now go over and turn the breaker back on and listen to the heater. KEEP HANDS AND EVERYTHING CLEAR OF THE THERMOSTAT IN THE OPENING.
Do you hearing gurgling or whining? This would indicate it is heating water. If you hear it, turn the breaker back off and put any insulation back in and replace the access cover. Go back and turn on the breaker and you are done. If you didn't hear anything now it is time to pull the lower access cover. Make sure the breaker is off and remove the lower cover. Repeat by removing insulation and pressing the button. Test by turning on the circuit breaker REMAINING AWAY FROM THE ACCESS.
If this time you hear hissing/gurgling/whining sounds it is on. Turn off the breaker, replace the insulation and replace the access. Now turn the breaker back on and you are done. If after all this you get nothing. It is time for a voltmeter and caution.
YOU ARE GOING TO WORK WITH HIGH AMPERAGE AC-IT IS DEADLY. RESPECT EVERYTHING YOU TOUCH AS IF IT WERE HOT.
HAVE SOMEONE WITH YOU WHO CAN FLIP THE BREAKER IF YOU MAKE A MISTAKE. THEY SHOULDNT TOUCH YOU UNTIL THE BREAKER IS OFF OR THEY COULD ALSO BE ELECTROCUTED.
You will need to remove each access door (with the circuit breaker off) and make it to where you can test for voltage on the power connections to the elements. Start at the bottom as this is the initial element powered by the unit. Put your voltmeter on a high scale (500VAC is good but it must be set to minimum 300VAC-High is fine-lower is bad) and put your probes on the 2 phillips head screws/bolts that the electrical wires connect on. You should see apx 220-240 VAC. If not, test from one screw to the metal fame of the tank where you see the green wire bolted to. You should see 110-120 VAC. If no voltage is at the bottom, the top reset isn't working. Try resetting the top thermostat again. Test for voltage at bottom. No luck? It may be time to replace the top thermostat/control. All major hardware stores sell them. Disconnect the wires and it should slide up and off the unit. Replace it.
If there is voltage at the bottom then the element is most like gone bad. To test this, turn off the breaker and unhook one of the screws that holds the power wire to one side of the element. Put your voltmeter on Ohms and test for a connection (continuity). If it shows a reading the element may be working or it may just have a small connection internally and fail when it is powered up. This is a tough one to diagnose outside the tank but if you see no connection (no reading) the element has broken in the tank and removal and replacement is in order. Turn off the water to the tank along with the breaker. Connect a garden hose to the valve at the bottom of the tank and drain the water out. Disconnect the wires and with a large element removal tool (you might get away with a large channel lock but if you round off the element you will hate yourself) remove the element. You can get the remover at the hardware stores for $8-10. The elements usually have their wattage on the end so replace it with the same wattage element. Reverse the process and lastly turn on the water, check for leaks then turn the circuit breaker back on. You should hear a hissing/gurgling/whining sound as the element heats up. good luck and BE SAFE!
Posted on Apr 01, 2011
How do i empty rheem warrior glass water heater
open the drain faucet on the bottom of tank after shutting off the inlet water
Jun 11, 2016 | Rheem Water Heaters
User manual for Rheem 21V30DV
1) 21V30DV is 2006 6-year mobile home (manufactured housing) natural-gas, atmospheric-vent water heater
2006 Manual does not show on internet.
Replaced by Warrior series
http://www.rheem.com/documents/warrior-dvx-warrior-dvx-use-and-care
http://hometips.me/Mar/Mobile-home-water-heater-illustration.pdf
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Add comment with specific question for possible help.
Mar 02, 2013 | Rheem Water Heaters
Rheem water heater flashes seven times ,it is in lock out mode
You have Honeywell electronic gas control valve, and error code is 7 flashes.
Probably you have power vent model.
One manual from different company says: "Reset gas control using on-off button on front of control, replace flammable vapor sensor, replace gas control thermostat.
But with Rheem you also need specific steps: Remove gas burner and look for broken glass vial, and then blow out arrestor screen air intake using compressed air, clean burner parts, check for unobstructed venting, you will need new glass vial from Rheem depending on year and model number of water heater that appears on label on side of unit, or they may not have a repair kit for that model, and you might need a new gas control valve depending on model and how extensive problem was
You have Rheem water heater.http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 28, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Where is the combustion shutoff system on a Rheem 30 gal moble home hot water heater
Disproportionate number of water heater problems are Rheem-related, yet Rheem is just 1 of 3 major water heater manufacturers.
If you have Rheem tank-type gas water heater, and the combustion shut off has tripped the FV system, then there is a broken glass vial located under the burner.
Rheem does not post service manuals, and they may or may not send the glass vial for replacement. Depending on model which appears on label on side of tank. Year of manufacture are 3rd and 4th digits in serial number.
And they may want you to contact a qualified service technician (plumber)
You will have to replace glass vial, and clean the arrestor screen and clean the combustion parts, check gas pressure, and check venting.
Other companies post service manuals and do not rely on the glass vial.
Copy following links:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
Sep 09, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Where is the reset button located on my Rheem Warrior Class Model # 71-522D
Question posted under Rheem electric water heater.
1) ECO red reset button is on upper thermostat, located under upper cover on side of tank.
It is covered with insulation. See images:
http://waterheatertimer.org/images/water-heater-thermostat2.jpg
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpg
2) Be sure to put cover and insulation back in place after pushing in reset button.
3) Push button inward very firm.
4) If reset does not punch back in, then replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Open following link for full troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem warrior glass serial num r0296b08705 model
You need to first determine if the burners light or not.
As long as the unit wasn't run with a dry tank the unit should not have been affected by continuous water running, unless it got hot enough to damage the thermocoupler which is an easy replacement. That is the part that your pilot/ignitor warms so that the gas valve will open the gas line to the burners.
Aug 12, 2011 | Rheem Single Water Heater Thermostat
Rheem warrior glass serial num-rh1098154699 model num-71-40d b That is all the information i collected off my hot water heater we have no hot water at all and i dont know how to fix this problem...
The label would also say if water heater is gas of electric.
That would be helpful information that could lead to troubleshooting.
Serial number tells us water heater was made on Nov 1998, which tells us the manual will not be on the Rheem website.
So if you have electric water heater, and no hot water.
There can be 4 causes.
1) Circuit breaker is not delivering 240 to water heater. Test top two screws on upper thermostat to see if tank has 240V.
2) ECO red reset button is tripped. Open top cover on tank and push reset button.
3) Upper thermostat is bad. Replace thermostat.
Nov 24, 2010 | Water Heaters
I have a warrior glass hot water heater.model number 71-305.serial number r 0590822159.wattage 240 volts ac only. 30 gallon.the water pressure is low.drained tank to clean out.still having problems.any...
Buy a pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Test pressure on water heater drain valve.
This will tell you if the pressure problem is before -or- after the water heater.
If problem is before the water heater, then the shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in the hot water outflow pipe on top of water heater, or a nearby elbow.
Nov 11, 2010 | Rheem Water Heaters
Kitchen Ranges Logo
179 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
