B&O DVD1 PLAYER DOES NOT OPEN ON DEPRESSING EJECT. NO DVD IN IN THE PLAYER. CONNECTED TO B&O BEOVISION. HAVE TRIED DISCONNECTING POWER. ANY SUGGESTIONS?
  • hswier Aug 05, 2008
    Yes this was helpful
    Guru:
  • 1,894 Answers
If disconnecting power does not help then you will have to open the player and make the DVD tray roll out.
Posted on Aug 05, 2008
  • 3,037 Answers
The motor for pulling the tray is probably shot. I have had it happen many times. I assume that this is a player with a tray by the sounds of your question. You can open the player and replace the motor with a new one. First test for power to the motor when you press the eject button. A electronics store can sell you the new motor and even test the current one for you. If you need anything else let me know
my best to you
    Master:
    Sergeant:
  • 462 Answers
Have u tried all the basic stuffs that cud get u solved with the problem..
  • Mohamed Ismail
    Mohamed Ismail Aug 05, 2008
    Be ready as u may have belt replacements also there may be lubcricants required for which u can use WD-40... it may also be a minute mechanism problem.. the tray might have settled down preventing it from ejecting...
  • Mohamed Ismail
    if u can hear motor rotating sounds or motor trying to eject or so this definitely describes it is a mechanism's problem..
Rockford fosgate rav dvd1 where can I get repars
Prob cheaper to replace, those problems are two different circuits! $$$$$
May 06, 2014 | Rockford Fosgate RAV DVD1 Car DVD Player
Dvd won't open
My only suggestion on this is to try depressing and holding down the eject button on the blu-ray player for an extended period of time (10 - 15 seconds).
Mar 11, 2014 | Sony Rdr-vx515 Dvd Recorder / Vcr Combo...
Battery was changed now the radio stuck on a screen which says eject DVD, eject CD, OPEN
If you can get to the back of the DVD player itself, you can try and kill the power to it and hook it back up. Sometimes, the software gets stuck when its not powered down correctly.
If you cant get to it, try disconnecting your battery, waiting about 30 seconds and then hook the battery back up.
Mar 03, 2011 | Eclipse AVN5500 Car DVD Player
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
1999 Ford SE digital display reads ''NO CD'' and changer is stuck
Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
Apr 15, 2017 | 1999 Ford Taurus
Beovision 7-32 with integrated DVD player won't load DVD's. Tray closes, but won't load the disc and opens again.
Beovision 7-40 i've got has done the same thing.... it will cost me around £600 to replace. the say they dont repair it they just replace it, how rubbish is that! what is the type number of your beovision 7 ? as i might be able to help you.
Nov 01, 2009 | Televison & Video
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Beovision 7 broken dvd player
all dvd problems are resolved by dvd mech. replacement/exchange,see your local dealer
Jul 06, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
May 30, 2008 | GE JASRM24912 Remote Control
NS-DVD1
YEs.REMOVE DISC
TURN PLAYER OFF
TURN PLAYER ON
OPEN TRAY
ON REMOTE PRESS 9-7-3-5
Box appears on screen use up and down arows to select REGION ONE or ZERO
PRESS ENTER ON REMOTE
TRAY SHOULD CLOSE
ENJOY YOUR DVDS
Dec 12, 2007 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
