Question about Emerson Microwave Ovens
Microwave does not work , and has lost power .plug in o,k,
  • Emerson Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Posted on Apr 01, 2011
No power to my Panasonic microwave
assuming u have pwr to the plug - and nothing lights up = it is probably a bad transformer - open thermal fuse.
WHICH was probably caused by a shorted mag, which means junk.
Feb 02, 2016 | Panasonic Genius Prestige Inverter...
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
Microwave stops randomly on its own, dispaly flickers and I get prompted to enter clock settings, what should I do to fix it
When a microwave asks for the clock settings, it has lost power. Check the plug and the outlet for damage or if it is loose. When on, vibrations can cause the plug to reposition if loose enough. Even a very short loss of power will reset the microwave. If the plug/outlet is ok, then check to make sure that the fuse for the outlet is tightened fully (breaker switches do not have this problem). Last, try another outlet as the wiring to the outlet may be loose.
Feb 11, 2012 | Danby DMW773 Microwave Oven
Lost power and when power came back on the clock would not reset.
Try disconnecting power for 5min.then plug back in,The microprossor may have locked up this happens a lot with uprocessor controlled equipment.
Jan 27, 2011 | GE Advantium 120 Convection/Microwave Oven
Power quite one day it lost power like curcuit broke there is power to the outlet
If there was a power outage, and then your microwave oven never came back on. Then it could be a possible fuse problem. If the circuit breaker had tripped, then after you turned off the cir. brkr. and turned it back on, then everything should've worked fine. Again, I would lean towards a blown fuse in your microwave. Now you're saying there's power to the outlet, and it still won't go on? Then my easy solution would be to plug it into another outlet, and try it again. Your problem could be that plug. After doing everything I just suggested, at any time did you get a digital readout on your time display in the upper right hand corner of the oven. Basically, is there any lights on at all when you're plugged into the wall. If not, then the problem is in the microwave itself! It could be just as simple as a blown fuse, but I would like you to try these other alternatives first. Feel free to contact me again if these don't work. Good Luck, and I hope I've helped you some. Let me know, Jim
Apr 06, 2010 | General Electric Microwave Oven
GE Spacemaker Microwave lost power
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I cleaned it now it won't work, it's not showing the clock, so wondered if it just needs clock reseting
what did you clean it in??? the dish washer???? some times if the plug is removed on an older unit or the power turns off, they just wont start up again,,, its a fult with the micro chips in the computer, the suden surge of power when switshed back on just blows it up,,, iv lost at least 3 in this way
you could try pulling the plug out again but its not very likely to get it working again the real problem is they just dont build in a soft start on them now, so if unpluged then switched back on the computer get a wopping big smack of power that just blows is socks off,, like i sead, i lost 3 evey time the power was cut off they died on me
Oct 21, 2009 | Panasonic NN-T888S Convection/Microwave...
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
My maytag microwave lost power
There is always a fuse inside a microwave.Sometime this has only blown due to a surge,and upon replacing, the microwave will continue working.If it is something worse the fuse will continue to blow.In this case it could very well be the transformer,but there are other possible causes as well.(for example the control board or a short.)
Jun 24, 2009 | Maytag MMV1153A Microwave Oven
Microwave lost all power when I pressed start
Plug a lamp into the circuit where the Microwave is plugged in. If the lamp comes on then you know there is power supplied to the microwave and the problem is one of an internal nature. If your light does not come on then your breaker at the main power panel could have tripped. On each breaker is a number which is its rating in amps. Your Microwave may require a 20 amp circuit.
May 11, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave Ovens Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
