Question about Crossfire XP1000D Car Amp
May problem how fics the pin code - Crossfire XP1000D Car Amp
Mag code k pa wag kana mag asa jan sa cheat
Posted on Apr 01, 2011
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
I need to know where to connect the three seperate 2 pin connectors from the ''power switch'' to the motherboard on my eMachines C2685 desktop computer.
The eMachines C2685 uses an FIC VC37GV motherboard. (First International Computer, Inc.)
http://www.motherboards.org/mobot/motherboards_d/FIC/VC37GV/
Here is the motherboard manual,
http://www.ime.org.uk/pdfs/vc37_vg31_b1_eng.pdf
After you click on the above link, give it up to 30 seconds to download. This is a PDF file.
Barring you cannot download the file, I will state the connections for the Front Panel header on the motherboard.
(Plus state the page to reference to, in case you can download)
View the first link, with the photo of the FIC VC37GV motherboard.
As shown, Processor is at the top, Ram Memory slots are to the right.
The Front Panel header is located at the very bottom right corner.
It is parallel to the outside edge of the motherboard. There are two rows of pins.
(Page 12)
The Front Panel header has 5 pins going across the top, and 4 pins across the bottom.
The top row of pins are numbered Odd.
The bottom row of pins are numbered Evenly.
On the Top row starting on the Right side, going towards the left, the pins are numbered 1, 3, 5, 7, and 9.
On the Bottom row starting on the Right side, going towards the left, the pins are numbered 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HDD LED. (HarDDrive activity LED)
B) Pins 5 and 7 are for the Reset switch
C) Pins 2 and 4 are for a Dual Color Power On LED, if used.
Green goes to Pin 2. Yellow goes to Pin 4.
Otherwise Pin 2 is Positive, ( + ), and Pin 4 is Negative. ( - )
D) Pins 6 and 8 are for the Power On switch.
(PWR1, or SW1)
There is a small 3 pin header, just above the Front Panel header. (Page 12)
This is for a Power LED that has either two wires, or three wires.
The pins are numbered from Right to left.
Pin 1 is for the Power LED, and Pin 2 is for Ground, if using a two wire Power LED. (Not dual color)
Pin 1 is for the Power LED, and Pins 2 and 3 are for Ground (GND), if using a three wire Power LED.
(Page 13)
May 26, 2010 | Computers & Internet
HAVE FIC AM 37 MOBO AND THE SW POWER ON IS DISCONNECTED, NEED TO KONW WHERE TO HOOKED THIS BACK ON
It needs to be connected to the F_PNL connector, located near the battery.
It has the following pin assignment:
L+ L- P P x
H+ H- R R N
L ... Power LED
P ... Power button
x ... missing pin
H ... HDD LED
R ... Reset button
N ... not connected
Mar 17, 2010 | FIC AM 37 Motherboard
I CAN UPGRADE MEMORY IN MOTHERBOARD FIC AM35, TO DDR (2)512M 444MHZ
Hey,
Yes, here are the details
Memory Max Supported RAM2 GB Memory TypeDDR SDRAM Supported RAM Speeds100 MHz · 133 MHz Number of Memory Slots2 x 184 Pin DIMMs Let me know if you need anything else. Thanks, Ekse
Feb 18, 2009 | FIC AM 35 Motherboard
Fic k7mnf-64 motherboard socket 462 amd 3000+ When I plug the computer in all that happens is a red light on the board comes on and a buzzer goes off.
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
Dec 18, 2008 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Jumper settings for an AMD 550 mhz K6-2 chip.
If you still have your manual, see page 19. Set CPU External bus frequency (100MHz) as shown & CPU to bus use 5.5x = 550MHz.
You can download the manual here:
http://www.fic.com.tw/support/download.aspx?dl=motherboard%2fmanual%2fsocket7%2fva-503%2b%2fva-503%2ba4sh.zip&title=va-503%2ba4sh.zip&info=manual
There seem to be more setting after going over the manual.
Any of these power supplies will work with the FIC board. All come with the 20-pin ATX main power. Some come with 24-pin power connector that you just do not use.
As far as finding a power switch for an ATX power supply try looking to a Good Will store. Most places have old PC parts for sale cheep. or try here: http://www.trianglecables.com/atxcaspusbut.html
http://www.directron.com/switchat.html
Good luck skivvynine!
Hope you find all this helpful.
Mike
Dec 17, 2008 | FIC VA 503A Motherboard
FB11 1.4ghz Pentium 3-S not working.
the 1.4 chip is a tulatin, the 440 bx will not support a tulatin, even though it has the same pin-out as a p3 coppermine. i dopue that it would work on any socketed board either.
Aug 14, 2008 | FIC FB 11 Motherboard
NEED TO KNOW WIRING
i have been to fic's web site, i cannot find any mb labeled au31.
do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc?
however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
Oct 17, 2007 | E-Machines eMachines Desktop PC
Crossfire XP1000D Car Amp Logo
48 people viewed this question
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
