Question about Dell Latitude D820 Notebook
Hi i have a dell latitude d820 laptop. i've had it since 2006. lately i have been having a problem i call "ghost mouse" the pointer on the screen starts moving all the way to the upper right corner of the screen on its own and it gets stuck there, i cant do anything about it. can you help? thanks
    Scholar:
  • 72 Answers
First off, my general rules for dealing with mouse problems:
Your mouse drive may need updating or replacement if it got corrupted.
Your mouse to computer connections may be loose.
Or, your mouse itself may be dirty, so you need to clean it as per your manufacturer's instructions.
Now, let's get into some specifics.
The first thing I would look for with optical mice is any sort of obstruction under the optical sensor. Sometimes dust, lint, or similar impediments get stuck between the optical sensor and the surface your mouse sits on, causing unexpected behavior. My second guess would be a surface that isn't favorable for optical mice. Optical mice have problems on porous surfaces and surfaces like glass. Typically this causes more frequent and obvious problems though. To eliminate the surface you are using as the problem, try putting something like a blank piece of paper under the mouse and see if the problems continue. It's possible that something has corrupted your mouse driver. You can either 1) re-install the driver, or 2) roll back the driver. Either one of these may help. To roll back your driver in Windows XP, go to Start --> Settings --> Control Panel --> Mouse. Click on the "hardware" tab. Select the appropriate pointing device, and click "properties." Click the driver tab, then select "roll back driver." Under the "hardware" tab, there may be more than one mouse. If this is the case, select the one that is not used, follow the settings above, and then select "uninstall." Or, you can go into Control Panel --> System --> Hardware --> Device Manager, and remove the device under "Mice and other pointing devices." Note: if you are on a laptop with a touchpad that you never use, don't remove the touchpad anyway.
Hope that all helps you debut your problems!
Posted on Apr 01, 2011
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 85 Answers
Your mouse is broken or you have something caught in the sensor look on the bottom of the mouse and make sure there isn't a piece of hair or dirt blocking the light even only a small spec will do that
I need a free manual download for the Dell Latitude D820
You can download the manual by clicking here
Hope this helps.Thanks!
Oct 20, 2011 | Dell Latitude D820 Notebook
I want dell latitude d820 webcam drivers plzzzzzzzz........help me
Hi jyothi_pr898...
Go to the following webpage and download the FREE driver you need.
Please take time to rate me
http://download-drivers-free.com/free-download-dell-latitude-d820-webcam-drivers/
Sep 17, 2011 | Dell Latitude D820 Notebook
Touchpad/Pointer do not function when pressed/glided ...Dell Latitude D410 w/ Windows XP Facts / what i've done: 1. BIOS - is set to use both Touchpad and external USB mouse 2. Turn computer off &...
Hi! Welcome to www.fixya.com.
You can try to download the Alps driver in this Link; http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If nothing happens after reboot: Its definitely a hardware issue. You have to call out fo warrant department your manufacturer so it will be fix.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 26, 2011 | Dell Latitude D410 Notebook
Unit Dell latitude D820 laptop O/S windows xp pro. Am using touchpad, have don all adjustments but my mouse pointer still drifts. sometimes it is also hard to control, meaning it does not move if I wantg...
click start control panel administrive tools computer management device managerscroll to mice and pointing devices + to expand right click you will the options to update drivers software, disable, uninstall scan for hard ware changes and properties select properties you will see more tabs,generaldriver,details,and power management.
select the driver tab you will have similiar options driver details,update driver,disable and to uninstall
you might have to uninstall the mouse and its drivers then reinstall them
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 10, 2011 | Computers & Internet
SM Bus Controller (for Dell Latitude D820)
open link and download driver .....
driver name chipset .....
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=LATITUDE%20D820&os=WW1&osl=en&catid=&impid=
Oct 17, 2009 | Dell Latitude D820 Notebook
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Dell Latitude D820
go to dell.com website at the bottom select "drivers and downloads" then select either your service (located on bottom of laptop) or your model number. Then select either XP or vista and the main drivers you need are you chipset, network, graphics, and sound.
Apr 01, 2009 | Dell Latitude D820 Notebook
Right arrow key writes n- bbb n- n- etc.
Remove the keyboard and reseat it. There are three screws to remove and it is very easy.
Nov 14, 2008 | Dell Latitude D820 Notebook
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Dell Latitude D820 Notebook Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
