Question about Delta & Single Handle Shower Faucet
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is there a special trick I can use to activate the shower?
    Problem Solver:
  • 9 Answers
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Posted on Apr 01, 2011
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
The Screw on the Delta Faucet handle just wont come out (1400 Series single handle). What can i do to take this off
HELLO- Screw could very well be stripped,gentley try to pull on the handle as you turn the screw counter clockwise, if you are able to get the screw out and handle will not come off, chances are you will need to get a handle puller Home depot / local plumbing shop or hardware store. goodluck
May 19, 2011 | Delta & Single Handle Shower Faucet
I am trying to pry the plate off on my Delta Monitor shower faucet. It must be an older model and it is not the plastic handle but a smooth stainless steel handle. It has a plate on the front that will...
I believe the older ones were held on by center threaded on piece, after you remove the handle. It's threaded on behind the handle, round cover over stem. Turn counterclockwise to remove it, then plate should come off.
Oct 31, 2010 | Delta & Single Handle Shower Faucet
How do you remove the temperature knob and cover from a delta shower faucet, model 1824 (Monitor 18 series)?
http://www.deltafaucet.com/customersupport/documentation/1824-74.html?document=pd&documentIndex=0 The very center piece of the temperature setter pops off with a screw driver. Remove the screw underneath it and everything else to the handle comes off. Firmly grab decorative sleev behind handle and pull. Firmly grab round brass collar and turn counterclockwise. carefull pry cartridge from brass body.
May 22, 2010 | Delta & Single Handle Shower Faucet
Series 1400 single handle shower can't get handle off
the local hardware store will sell you a handle puller, cheap, maybe $10
Mar 21, 2010 | Delta & Single Handle Shower Faucet
How do you remove cartridge from 1400 series delta shower valve
Take off the handle and the cover piece. There is a large nut holding the cartridge in. Be careful taking it off so you do not twist the cartridge socket off the rest of the valve.
Oct 27, 2009 | Delta & Single Handle Shower Faucet
Delta Series 1400 shower faucet, no or very little water out of the cold side of the faucet. Plenty of hot water. What can I do to fix this?
Remove the handle by opening the little red/blue cap. Use a hex key to remove the handle. Remove the tope ring holding in the cartridge in. Take out the cartridge and you will most likely see particles blocking it. make sure you use a little valve lube or vasline on the seals before you put it back in so you will have smooth operation. If that doesnt cure it just replace the cartridge at lowes or home depot and bring the old one.
Sep 22, 2009 | Delta & Single Handle Shower Faucet
How to turn on shower head of Delta monitor
I'm at my cousin's place and he has a delta monitor. Similar to what you guys are talking about.
To turn on the shower, I had to pull down on the faucet head, not the shower head.
To turn off the shower, I had to push the faucet head back up.
Hope this helps anybody out.
Mar 24, 2009 | Delta T13420 Chrome Classic Single Handle...
I have a Delta Series 1400 faucet in the tub/shower. The handle turns left and right for Hot & cold, but I do not know how to adjust total volumne. Is the round know supposed to pull out? It does not...
hi roger,
Sorry Delta 1300 and 1400 series valves do not have a volume control. Kinda odd but that is how they are made.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
Delta & Single Handle Shower Faucet  Logo
392 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
