Question about Oritron OP1181 CD Boombox
I have model # OP1033NR and the cassette player has started dragging very badly. Can I get a new belt for the tape player?
  • stretchb Apr 01, 2011
    Thanks so much for a solution. I hope it works. We'll see.
    Thanks again!
    I will accept this answer because the belt is what my husband says is wrong with it and we will get the belts and try them out. Hopefully this is it.
    THANKS
  • 2,098 Answers
Hi stretchb,
I've tried to look in my link to get the exact replacement belt of your model but it was not available. You may try this replacement belt for your cassette.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 01, 2011
  • Jdvillanueva
    Jdvillanueva Apr 01, 2011
Cassette tape will not play, just screeches, why
Without a make and model, the only suggestion I have is bad belts. Some players can require a lot of disassembly to get the new belts on. If you go to Turn Table Needles, they have a nice feature where you can enter your make and model number to see what belts you will need.
Dec 12, 2017 | Audio Players & Recorders
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Cassette player quit working on crosley cr24-003
Check its belts. Replace them. Belts can be bough from most of the electronics spare part selling shops at your town. They are available in kit form, according to model number of your player.
Jun 06, 2012 | Audio Players & Recorders
Requestin replacementsize of belts for Sony TC WE305 cassette player, not a boombox
A Tv repair shop carries a large stock of belts, probably a good place to start. The other option is order from Sony online and ask for the Technical Department.
Feb 17, 2012 | Audio Players & Recorders
How do I record my cassettes into my PC
find a tape player/recorder than has the capability to connect to a computer connect your tape player/recorder to your computer open windows explorer navigate to the tape player open it then select the files you want to copy to your computer right click select copy then navigate to the place where you want them saved or you can select the files hold the muse cursor on them drag them to the place you want to save them and drop them into it
hope this helps
Nov 28, 2010 | Behringer (UCA202) Sound Card
My cassette player on both side's will not play
Most likely cause are bad belts, when you have the play button only partly pushed in the pinch roller is not fully engaged. When you push it in all the way the drag is too much for the worn belts and they are slipping causing the cassette to drag.
May 08, 2010 | RCA RS1285 CD Shelf System
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
I think the actual tape cassette is the problem not the player. olde tapes play very slowly, dragging, distorted sound. New tapes are fine. What can I do to re-vitalise the old draggy cassettes?
Actually the tape player itself is likely to be causing the problem. Cleaning the pinch roller and tape heads with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | Audio Players & Recorders
Oritron OP1181 CD Boombox Logo
67 people viewed this question
Top Oritron Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Oritron Audio Player and Recorder Expert? Answer questions, earn points and help others
