Question about Panasonic KX-T7735 Corded Phone
How do I program caller id on KX-t7735 - Panasonic KX-T7735 Corded Phone
  • Panasonic Master
  • 2,460 Answers
It requires a -93 card and some programming in the 900's to make it work.
Carl
Posted on Apr 01, 2011
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
We have a panasonic KX T7735 phone system at home and I'd like to know how to set up caller ID for this system
You need 3 items, CID service from the telco, a CID card in your Pana system (TA82493, TA62493, etc.) and some programming. The Installation manual and Programming manuals have the procedure for installing and programming the phone system.
Carl
Sep 22, 2011 | Panasonic KX-T7730 Corded Phone
How can i se the numbers i have received and the missed calls in my panasonic phone KX-T7735
Hello, I have a Kx Td1232 with a KX-T7735 and program 96 and 99 does not work. What do I have to do? Thank you.
Sep 14, 2011 | Panasonic KX-T7735 Corded Phone
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
I installed a caller id card in my kx-ta624 panasonic system in my home. The manual I have describes kx-t7030 phones with a caller id indication button but my phones kx-t7730 do not have a button and so I...
You get to program it :-)
In the User's manual section 2-2 there's an alpabetic index for Caller-ID. It requires 2 buttons, a CID-Indicator and a CID-Select button. We usually put them as the top 2 buttons in a 773x series phone, but you'll have to pick 2 adjacent or similar CO buttons. You label them CID-I and CID-S. Then you program them for either 96 and 97 or 6 and 7. You also have to tell the programming that you are setting up the common CID if you use 96&7.
Carl
Dec 12, 2010 | Panasonic KX-T7730 Corded Phone
How do I change the clock on the panasonic kx-t7735
www.westlake.co.uk/KXT7700-User-Guide.pdf
http://www.retrevo.com/support/Panasonic-KX-T7735-Telephones-manual/id/2915ag913/t/2/
Hi please find above your user manuals to download, inside it explains it all step by step...
Nov 08, 2010 | Panasonic KX-T7735 Corded Phone
Caller ID problem with KX-FHD332
Your fax machine does not actually have CALLER ID, it reads what the sending fax machine has programmed into it. If it was never entered in, you won't see it.
Jan 13, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
Caller id
Yes, u need to program all the caller information into the phone. Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
Aug 04, 2009 | Panasonic KX-T7633 Corded Phone
How do i clear caller id numbers on the kx-t7735
This depends on your system. For a TA series and maybe some others, personal CID can be cleared with the command 70*#. System CID clears from an Operator or manager's phone with 70**#.
Again, if your system is NOT a TA, it might be a different command.
Carl
May 05, 2009 | Panasonic KX-T7735 Corded Phone
Panasonic KX-T7735 Corded Phone Logo
136 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
