I need driver to set up my linksys WRT54 G vr. 5
  • Coss May 11, 2010
    A driver is a set of instructions that tell a piece of hardware how to work with a computer, like a printer, or a video card.
    You don't need a driver for a router.
    You just need to connect to it. It is not an attached device like those mentioned.
    What is it you are trying to do?
  • 659 Answers
Click here for linksys info on the unit you have
click here for a driver for your wrt54g ver.5
Warning I have not tested this driver so not sure if its correct.
also scroll about 3/4 the way down the page it will want you to enter and code and then go for it.
Posted on Aug 05, 2008
I have lost the password to my lynskys /wrt54/g router, how can I retrieve it or change it?
Try http://www.linksys.com/connect and if unsuccessful, there is no way to 'retrieve' a router password. If you forget it, you will have to factory reset it
Open a web browser and enter the address "http://192.168.1.1" in the address bar.
Leave the user name blank and enter the password "admin" without quotes. This is the factory default password
Jul 15, 2012 | Linksys Wireless-G WRT54G Router
When i connect all cable my Linsys wrt54 g is not workin and my indternet conction.
First, make sure that all your cables are plugged in correctly. If everything is connected correctly, the lights on the front should start blinking. Once they start blinking, you can follow the guide here:http://www.columbia.edu/acis/networks/aptnet/linksys/index.html This guide will help with setting up the router, as well as making it secure. Hope this helps!
Mar 28, 2011 | Linksys Wireless-G WRT54G Router
I have to configure a Linksys wireless router WRT54GS that was installed prior to my arrival here, no info on login info avail. All lost or forgotten. I have tried admin/admin...and just admin with no...
There should be a reset switch on the back of the router..press and hold this for 30 seconds to reset to the "admin" password..the wrt54 default password is admin and there is not a user name when it is reset
Jan 04, 2011 | Linksys Wireless-G WRT54GS Router...
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot access the internet through the router. Seems like the router and the modem are not communicating. When I bypass the router there is no problem.
make sure the router does not have the same ip address as the modem. change the last on the router xxx.xxx.xxx.001 to xxx.xxx.xxx.002
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54 GC failed auto port forwarding
check in your pana sonic ipadreses then test in your network can you able ping of ip of cam?
If you can get ping and if you save ip forwarding port 80 to cam ip then check in camera that the settings of "access via interent is enabled" then you cana cces it with cam ip with 80 http port.
Jul 27, 2009 | Linksys WRT54GC Wireless Router
Bridge or Repeter mode.
It is possible but you will need to flash the router with custom firmware.
Here is how:
http://www.dd-wrt.com/wiki/index.php/Installation
This is only possible if you have two wrt54-g routers that are of one of these types:
WRT54-G ver 1
WRT54-G ver 2
WRT54-GL
(there is a sticker on the bottom that can tell you what version it is)
This is the article that I followed and it workes great.
http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Apr 29, 2009 | Linksys Wireless-G WRT54G Router
I am trying to reload my disc for my Linksys WRT54 V5 router and it won't go past the password and everything I have tried it won't move on. How do I reset the whole system and put in a new password.
look on the back of the router there should be a reset button
i had this problem when i had a linksys router
i used there automatic installer
Jun 27, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
