Question about Refrigerators
The controls and in japanese and dont understand what controls mean in english on the little door panel located on end bottom of right handed top door. the fridge works and after few hours red light appears at the panel. Dont know what it means and what other green lights mean. CAN YOU HELP PLEASE. THANK YOU LOUIE
  • 731 Answers
Maybe... if you provide make and model of the machine
Posted on Apr 01, 2011
Change Japanese language to English
I think you'll find that the word 'Stereo' is in fact from the Greek, not Japanese.
Apr 28, 2016 | Cameras
Change language on car radio from Japanese to English
Best to call your dealer on this one.May have to replace stereo or learn japanese.
Nov 26, 2013 | 2005 Nissan Murano SE
I need to change the language of my hdd navigation system. nhdp-d54. from japanese to english.
  1. Changing Japanese language to English setting on 2014 ...
    ? 0:45 on GOOGLE
    www.youtube.com/watch?v=Q4LtKzPk0W4Jun 20, 2014 - Uploaded by rehtis00 2014 Right Hand Drive Toyota Landcruiser with navigation option.... alarm but is in Japanese i don't understand , i have a pic can i send to you and can u translate for me? regards .... Usually, in the older units the language is in the firmware, not the DVD orhard drive. ... Japanese Car Navigation System!
Feb 23, 2012 | Cars & Trucks
Sony cybershot dsc w320. A gift from my cousin in japan. I cant change language from japanese to english. I tried the menu then the language. I dont see any other options for language. Well, Im not really...
Press the Menu button, the one the top left of the control panel. Look for an icon shaped like a tool box, and press the central button on the control panel. Select the category that has an icon that looks like a hammer, that's the Main Settings. The second option there is the Language Settings, press the central button on it to get a list of available languages, English should be there, just get over it, and press de Central Button again and there you are.
Mar 14, 2011 | Cameras
Japanese to English
CONVERT JAPANESE TO ENGLISH GO TO THIS LINK http://translation.babylon.com/japanese/to-english/
OR USE GOOGLE TRANSLATOR
Nov 13, 2010 | Computers & Internet
What does dL F mean
Hi
Thanks for using FixYa. Error "dlf" means a door latch failure. This means that you'll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it's unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel fried???
Hi
Thanks for using FixYa. Error "fld" or “dlf” means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sonic Secret Rings Wii~Change from Japanese to ENGLISH?
Ok, i just figured this same problem out. When you get to the main screen press 2 then you should have 4 options to choose. Pick the bottom right one. After doing this you will have to pick the top selection then the 2nd one in the little box, this will switch the text language. Have a good day.
Jun 04, 2010 | Sega Sonic and the Secret Rings for...
The language is coming in japanese, want to change
hope yours is not an overseas model.japan made and meant for japanese market at times doesn't have an english language option setting.but lets try to find out and see if this helps.open the lcd panel.touch p-menu (located at the bottom right corner of the lcd screen).then touch menu.(first boxed item at the upper right hand of the screen)..you should see a circle w/icons on it and an up and down arrows at the top and bottom of it.use the arrows to move up or down the menu items.go highlight the icon that has a clock and a globe.now press ok (located at the bootom right side of the screen)it should give you 3 items.last one item is for the language settings.highlight it and press ok again.now,this last part you might need to select one setting at a time (don't forget to press ok once you selected a setting) until you come up w/the english language option. hope this serves you.goodluck.
Mar 19, 2010 | Sony Handycam DCR-HC90 Mini DV Digital...
Washer error code is F 11. will not let me reset
There is a small cover on the front bottom of the washer. Remove it and there should be a door release rod that you can pullto unlock
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
