Question about KitchenAid Dryers
How do i change the belt on my kitchenaid dryer
    President:
  • 1,273 Answers
Hello, W/D here.
Unplug the dryer first! Place the belt on the drum, then the motor pulley. Raise the tensioning pulley past the belt, and let it come to rest on the belt, placing it in tension. Roll the drum over several times by hand to align the belt on the drum, and close it back up.
Best regards,
--W/D--
Posted on Apr 01, 2011
Getting to drum in kitchenaid dryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
Jun 04, 2012 | KitchenAid Dryers
My kitchenaid dryer will heat up but wont spin around
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
Kitchenaid keys700gqb isn't getting power to the moter, the doors switch clicks, the light is on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 06, 2011 | KitchenAid Dryers
The drive belt broke
Hello there and thanks for cfhoosing fixya
Here is a listing of the belt diagrams and a part number for you ok?
Belt, Drive
Item # 529597
img-descriptiontab-on.png img-repairgurutiptab-off.png Dryer belt. This is the most common belt used on Whirlpool, AMANA Kenmore, Kitchenaid, Roper, Estate and other dryer brands. The belt is flat, 92-1/4 inches long, 1/4 inch wide and has 4 ribs and 3 grooves. It replaces many other belts, including some with 5 ribs and 4 grooves.
img-descriptiontab-off.png img-repairgurutiptab-on.png See our dryer belt diagram to see how this belt should be installed around the motor and idler pulleys.
Watch Video
Order now and choose FedEx 2Day or FedEx Overnight shipping and this item will ship out today - or it's FREE!
$11.20 Quantity:
In Stock
Feb 05, 2011 | Amana NGD5400TQ Dryer
My KitchenAid KEYS750LQ makes a squeaking noise sometimes while running and I was told it could be the dryer belt. What do you think?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | KitchenAid KEYS750LQ Electric Dryer
The dryer heats good but my whispering appliance now squels
The roller bearing on the belt's tensioner is at fault. Replacing the roller is the first step and also replace the belt too
May 13, 2010 | KitchenAid KEYS750LQ Electric Dryer
KitchenAid Dryer won't spin
Probably the motor control switch or thyristor or relay.
Jul 14, 2017 | KitchenAid KEYS750LQ Electric Dryer
How do you replace a band on a kitchenAid dryer
you remove the front cover,then top cover then re-string the belt around the motor pulley,drum, and the idler pulley, and manually rotate drum to align drum and put top and frt covers back in place
Sep 25, 2009 | KitchenAid Dryers
Dryer will not cycle
Replace the belt and all will work fine. The belt spins the drum
Feb 09, 2009 | KitchenAid KEYS700LQ Electric Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Open Questions:
Dryers Logo
123 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
