Question about Panasonic Video Cameras
Trouble with auto focus, need reset - Panasonic Video Cameras
    Genius:
  • 1,812 Answers
The most likely cause for this is a zoom or focus lens out of place or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Apr 01, 2011
Hesitation on the 2003 ford focus
Hello! #1...I need to know if the Check engine Light is on...If it is, take the vehicle to an Auto Zone or Advanced Auto (any auto parts store) and they, for free will read the code/codes...send the trouble codes to me and I'll fix your Focus...#2 tell me which engine is in the car; give me the sub model ie...SE, ZTS....etc...If there isn't a CEL tell me....Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 14, 2011 | 2003 Ford Focus
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Monitor auto-focus problem with HP windows 7
Go to the control panel (or it's equivalent) in Windows 7 and reset the monitor for a higher resolution which should reduce the image size. You may need to upgrade the monitor driver files for Win 7 so that 'auto-focus' is enabled.
Nov 03, 2009 | Computers & Internet
Auto Focus not working
It depends on how long you have owned the camera, but I find it doubtful that it would be waring out. Sometimes after messing with the auto focus buttons my camera no longer focuses on its own, I then reset the settings and re-select auto focus. This always fixes my problem. I hope you find a solution. God bless...
Aug 16, 2009 | Cameras
Trouble shooting in auto focus
Maje sure you lens it not set to manual focus and that the lens is mounted correctly. Also - FWIW - shoot with a fast shutter speed (1/250 or better) to avoid blur.
Apr 24, 2009 | Nikon D200 Digital Camera With 18-135MM
Hi there i have a auto focus problem. i used mt 50D for the first time on saturday, after about 100 shots Err99 appeared, i turned the camera off and took the battery out an the error message never occured...
The camera is having problems with your lens and this is why it goues into the error mode. Try first cleaning the interface contacts on the lens ( see enclosed pic ) . If this does not sort the problem out then the auto focus motor ( or related hardware ) inside the lens will need attention. Also try other lenses to see whether it is only the lens ( I very seldom see this sort of problem cause by the body ; it is always the lens that gives this sort of trouble )db49ae2.jpg
Nov 04, 2008 | Canon Cameras
DMC-FZ7 problems
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
Jul 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Nikon D70 SLR Auto Focus
problem in lens censer replace it
May 14, 2008 | Nikon D70s Digital Camera
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Low light with auto-focus
All auto-focus systems need a fair amount of light or contrast to work efficiently. If possible, raise the ambient light if indoors. Search for an area within the desired focusing point with contrast to focus on.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Video Cameras Logo
49 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
