Question about Apple iPod touch
ITouch pretending to be a camera question
I have a question about the iTouch pretending to be a camera subject. I went to the device manager and found the USB cable, clicked on it, pressed Upgrade Drive. Then i used the "advanced" choice, clicked "Don't Search" bubble. But in the list, i couldn't find my USB cable name. Can you help me?
  • 2 more comments
  • goldenpam Dec 03, 2008
    My iTouch thinks it's a camera. I've patiently tried everything and then last night I cleaned it's clock...only to realize it was not being recognized by my OS and therefore I could not do a restore. So, here I am with 32GB iTouch that currently is a paper weight. What do I do now. All I see is a USB cable and a CD on the screen.
  • john167142 Jan 24, 2009
    Hi just wanted to say that i had the same problem with my ipod and tried everything i could think of but to no avail however kcourt10's solution solved my problem so thanks very much
  • knadia Feb 10, 2009
    I followed all the steps til that last one when I chose the file and click OK it tells me " the specified location does not contain information about your hardware" ...does it mean I need to re install I tunes again and do all those steps?
  • Adrian Tanner May 11, 2010
    When you say you found the ipod cable, do you mean the ipod was plugged into the cable, or just the cable sitting by itself?
I hate to even try to explain how I was able to solve this problem because I am such a novice in this area but I was persistent enough to find a solution. After having found it am I sure I will struggle to remember all of the steps but I will at least try hoping to save someone the 3 hours I spent attempting to figure this out myself.
Step 1 -
I followed the advice from another thread on another website that said I should go to Start menu, click the "Run" icon and type in "devmgmt.msc". That brought up the "Device Manager". The other website suggested that I would find "Apple iPod" under one of the "USB icons" and by clicking on the "+" next to the icon I could locate it. However, when your iTouch is being recognized as a camera it does not appear under the USB icons. It appears under the "Imaging Devices" icon.
Step 2 -
Click on the "+" next to the "Imaging Devices" and "Apple iPod" should appear (if it doesn't, I apologize because I cannot explain to you from here where to go. If it does, go to Step 3.)
Step 3 -
Right click on "Apple iPod" and then click on the "Driver" tab, middle of the 3 tabs at the top.
Step 4 -
Click on "Driver Details" - the driver file name should end with "usbaapl.sys". If it does not, you do not have the correct driver installed to sync your iTouch. So you need to go to Step 5. If it does, again I apologize but my expertise has been exceeded and this solution is likely not for you.
Step 5 -
Close the "Driver Details" window and click on "Update Driver" - This will open the "Hardware Update Wizard" (if you are using Windows XP). In this window, click on "Install from specific location" button and click "Next"
Step 6 -
Click "Don't Search. I will choose the driver to install." and click "Next"
Step 7 -
Click "Have Disk" (even if you don't have a disk, I didn't and it worked anyway, because you will tell the computer where to find the "usbappl.sys" file eventually anyway.
Step 8 -
Choose "Browse" in the next window
Step 9 -
Go to your "Program Files" folder on your main drive (C: for me)
Click "Common Files"
Click "Apple"
Click "Mobile Device Support"
Click "Drivers"
Step 10 -
The file that appears in this folder is actually called - "usbappl.inf"
Select it and click "OK".
This made the final connection for me (somehow leading the computer to the "usbappl.sys" file which also is in this folder but does not appear as an option in the final step) and my iTouch began to sync within 5 seconds. Wow. What a relief. I hope this is clear and I hope this works for you. Sorry it is so long, but if it can save anyone a ton of time and frustration I will feel my time was well spent.
Posted on Nov 12, 2008
  • Apple Master
  • 13,433 Answers
Really delayed response.
You need to install itunes again, the itunes includes the usb driver and if its not listed you need to search for it.
open up search
type in
usbaapl
note where that driver is stored.
for example at c:\program files\apple\itunes\ (I just made that up its probably in another folder thats why we are Searching for it with the search tool)
Then go to device manager select the ipod, update driver, manually(as above), have disk - go to the address where the usbaapl is stored and click ok it should find the driver, continue, it should install the driver, and you are done.
Posted on Aug 22, 2008
Webcam not working on hp probook 4430s
try going to device manager, uninstall and then reinstall, this may work
Jan 25, 2013 | HP ProBook 4430s Notebook
Hi i have windows 7 and i found this to be a common problem. my iphone and itouch do not show up in itunes. and wen i furst plug my iphone in it shows up as a camera in devices. please help me get my...
hi , it sounds as if your apple services driver is not starting.
  1. Connect the device to the computer.
  2. Quit iTunes if it opens.
  3. Click the Start menu, right-click on Computer, and choose Properties.
  4. In the upper-left corner, click Device Manager. The Device Manager window should open.
  5. Click the plus (+) icon (or disclosure triangle for Windows 7) next to "Universal Serial Bus controllers" to expand this selection.
  6. Locate
    the Apple Mobile Device USB Driver in this list. In some cases, you may
    not see this, but will find "Unknown" in its name. In other cases,
    Apple Mobile Device may be located in a different section of the Device
    Manager, such as Other Devices.
then all you do is click to restart driver
good luck
nick
Sep 18, 2010 | Apple iPhone Smartphone
Each time when I plug my Itouch into my PC usb port, my PC reboot itself & I'm using XP, but when I try with my nano it's working perfect. Also it detect it as digital still camera, which I cant find...
Try and plug it up on the back of the computer, the ports on the back are better suited to power the larger devices. You will have to find the player in device manager in control panel. If it has a yellow exclamation mark or a question mark under other devices or as a camera delete it, and right click the small computer icon at the top of the tree and chose scan for changes. Then chose portable device. Next Xp or Vista will want media player 10 or higher to see your player, also you may have to turn off any anti virus that may cause a problem. Leave it hooked up for a while to be sure it has charged some.
Jan 25, 2010 | Apple iPod touch
I restored my itouch but itunes still wont recognize it
You may need to reset the driver
and then possibly update your itouch firmware to get it working again....
-Close any other open programs
-Unplug the iTouch and any other NON-ESSENTIAL USB devices from the computer (i.e. PRINTER, CAMERA, etc.)
-Open the iTUNES application and leave it on during this process, you may minimize the program if you'd like though!
-click on your Start Menu
go to Control Panel
click on System icon [computer w a check]
goto the tab that says Hardware
then the Device Manager button (alternatively, u can access the device manager by opening up the RUN command and typing in "CONTROL.EXE SYSTEM" and hit ENTER)
-Under DEVICE MANAGER, click on universal serial bus controlers
to expand the catagory
then you itouch should be in there
it may be under a name like "USB
Mass Storage Device"
then click [up/plus on the toolbar] and choose
the unistall driver option[computer with an X]
(don't worry, your data on the iTouch will be fine!)
-Next plug your itouch back in it should
recognize it
Now then, try to update the firmware through Apple
Jan 03, 2010 | Apple iTunes
I cant install itdont have a disk
Send a email to DQT2002A@yahoo.com Place ez 386 in the subject line. I found my cd and will share the drivers and help to get your cam working.
Jun 25, 2009 | Ezonics EZ368 Webcam
USB port not working
Are your Usb Ports listed in the Device Manager? If they are see if you can roll back the driver to an earlier date.
Mar 29, 2009 | Acer Aspire 9300-5349 Notebook
Crystal eye webcam not found
Make sure that the usb drivers do not have conflick right click on my computer and go to propertys open the device manager and see if there are any conflick of driver unistall the camera and drivers for the camera restart the laptop ad the setup disk and follow the prompts to reinstall the drivers if you dont have a setup disk download the driver and put them on a disk ,if you install from a disk you will have less chance of conflick than you would if you just down load and install from the internet.
Mar 15, 2009 | Acer Aspire 5315 Notebook
Itouch
hey Ekse, I tried this and there wasn't another driver what should I Do?
Jul 05, 2008 | Apple iPod touch
Apple iPod touch Logo
826 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
