Question about Whirlpool LEQ8611L Electric Dryer
DRYER BLOWER IS WORKNG BUT NO HEAT. HELP - Whirlpool LEQ8611L Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 01, 2011
Model rgd4400vq My dryer will heat for about 10 minutes then will stop heating if I try to start it back up right away it will not heat but if i wait for 30 minutes it will then heat up for 10 minutes...
The fuse is in tact then and the control is sending power to the gas assembly. the ignitor is workng and the flame sensor. So it must be those coilsthemobilian_333.jpgthemobilian_334.jpgThese coils are KNOWN to get hot and quit with age.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 30, 2010 | Roper RGX4634KQ Gas Dryer
I have a ge harmony gas dryer and the blower isn't work can this cause a no heat issue
Yes. The blower draws the air from the heat source thru the tub and out the blower exhaust. This link should help with the Blower wheel assembly they also have diagrams or illustrations of your specific model
Sep 23, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
DRYER TAKES ALONG TIME TO DRY A LOAD OF CLOTHES IT HEATS TO WARM CLOTHES ARE STILL DAMP FOR AT LEAST 2 HOURS NOTHING IS CLOGGED IN THE VENTILATION LINT CATCHER IS CLEAN HELP!!
You may have a blower which is not circulating enough air flow. You can have heat and no blockage but a blower whcih is not moving enough air to distribute the heat and displace the moisture filled heat to the exterior.
Mar 17, 2010 | General Electric DBXR463EG Dryer
87 dodge dakota heater blower stopped workng
The blower resistor will burn and smell without blowing a fuse
Feb 04, 2010 | 1987 Dodge Dakota
I have a chevy trailblazer 2006 and the heat stopped workng. What would cause that?
sorry for the delayed response, chances are you have a bad blower motor,to check this you will need to locate the blower motor under the passenger side of the dash, disconnect the 2 wire elect. connector, turn the key to the run position, now with a 12 volt test light or dvom check for voltage on the red wire and good ground on the black wire with the blower speed set to hi, if you have power and ground then you need a blower motor
Dec 01, 2009 | 2002 Chevrolet TrailBlazer
Dryer runs but no air circulating
love2fix,
First use the dryers service mode and make sure that you are getting the same information as you suspect:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Best of luck!
Apr 15, 2009 | GE Profile Harmony DPGT750EC Electric...
Blower doesn't blow and no heat
With these GE Harmony Profiles, the blower is the problem in same situations about 95% of the time.
First use the dryers service mode and see what trouble code you are receiving.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Oct 18, 2008 | GE Profile Harmony DPGT750EC Electric...
1997 Isuzu rodeo-dashboard light/air cond, heat not blowing
Easy fix. Usually the blower motor resistor gets messed up. (Page 3-8 Haynes manual 47017). The dash light could be a few things. All my bulbs went bad. Little bit of a hassle but no problem with the book.
Jul 17, 2008 | 1997 Isuzu Rodeo
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer not heating!! Harmony dpgt750ec
If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this. Good luck to you, mca0824@aol.com
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Whirlpool LEQ8611L Electric Dryer Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
