Question about MSI MS-1012 Notebook
Replace LCD My Ecs notebook was troble sith the screen. i decide to replace with other one (from samsung "14 inch). The data cable behind the lcd look same. but the slot shortest then the original one. How to fix it, is it work?
  • 409 Answers
Its the wrong screen.You will have to get the correct screen in order for it to plug in.
Posted on Jul 31, 2009
SOURCE:
Have a Galaxy Note Pro SM-P900. The glass screen on right side have warped. The right hand side of the glass now sticks up almost 1/4". Can it be fixed??
Screen is about $30. The whole thing with digitizer is $250.
Samsung Galaxy Note Pro 12.2 Screen Replacement and Teardown ...
? 39:59
https://www.youtube.com/watch?v=Nne3VC0GnBE
Nov 4, 2015 - Uploaded by Repair Tech Trendz
How to repair your Samsung Note Pro screen. Samsung Galaxy Note Pro 12.2 Screen repair. Compatible ...
Samsung Tablet Parts - Samsung Galaxy Note Pro 12.2 SM-P900 ...
https://www.parts4repair.com > Home > Samsung Tablet Parts Back Cover for Samsung Galaxy Note Pro 12.2 P900 WIFI -Black. ... Complete Screen Assembly for Samsung Galaxy Note Pro 12.2 SM-P900 P901 P905 -Black. ... Dock Charging Flex Cable for Samsung Galaxy Tab Pro 12.2 SM-P900.
Replace cracked digitizer front screen - Samsung Galaxy Note Pro ...
https://www.ifixit.com/Answers/View/187022/Replace+cracked+digitizer+front+screen Aug 19, 2014 - A 12.2-inch "prosumer" tablet released in February 2014. ... Hi, just tried to replace the front digitizer touchscreen on this device, however despite being able to source a digitizer it appears to be glued to the LCD via a clear double sided sheet and I have managed to destroy the ...
Samsung Galaxy Note Pro 12.2 SM-P900 Replacement Parts - ETrade ...
https://www.etradesupply.com/samsung/tablet/samsung-galaxy-note-pro-12-2-sm-p90... This OEM Galaxy Note Pro 12.2 SM-P900 includes lcd screen and digitizer assembly, Galaxy Note Pro 12.2 SM-P900 battery, Galaxy Note Pro 12.2 SM-P900 ...
Galaxy Note Pro 12.2 Screen Replacement Kits ' Display Glass Repair ...
https://www.repairpartsplus.com/Galaxy-Note-Pro...Screen-Replacement-Glass-Repair-... Galaxy Note Pro 12.2" Screen Replacement Touch Display Black Samsung Galaxy Note Pro 12.2" Screen Replacement Glass Touch Digitizer P900 P901 P905 ...
New touch Screen LCD Assembly For Samsung Galaxy Note Pro 12.2 ...
https://www.ebay.com > Cell Phones & Accessories > Cell Phone & Smartphone Parts New touch Screen LCD Assembly For Samsung Galaxy Note Pro 12.2 SM-P900 W/Frame ' Cell Phones & Accessories, Cell Phone & Smartphone Parts ' eBay!
galaxy note pro sm p900 replacement screen Google Search
Jun 08, 2018 | Galaxy Cell Phones
Samsung nc10 screen goes black. its power on i can see only a dark screen and a little image on the screen
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Samsung NC10-14GW Notebook
Laptop Screen Repair
The screen will cost at least $200.00 plus labor (approx. $85).
you will need to remove the upper lcd display casing, remove the screen that hold the screen to the bottom lcd display case, and remove the data and inverter cable.
one website that sells screens is:
http://www.lcds4less.com/DellLaptop__Dell_Latitude_E4300__laptop-screens.html
Feb 27, 2010 | Dell Latitude E4300 Notebook
My LCD has hizontal lines appearing. But if I press the side of the mounting in goes back to normal. Seems like something is loose inside, what could I possibly do? Thanks!
Warning: the LCD screen can be easily damaged if you open it up. If you do something wrong the screen might become completely unusable and you’ll have to buy a new screen. It’s very expensive. Think twice before you decide opening the screen. Continue at your own risk.
  1. First of all remove the battery from the notebook.
  2. Lift up rubber screw seals and remove all screws.
  3. Carefully separate the screen bezel from the LCD cover and remove the bezel.
  4. Remove the screws from the front and from both sides.
  5. Carefully remove the LCD screen from the cover and place it on the notebook base. Disconnect the video cable and the inverter board cable.
  6. Disconnect the screen cable and remove the inverter board by removing both screws holding it.
  7. Clean the terminals then reattach the cables firmly.
Oct 19, 2009 | Toshiba SATELLITE PRO 6100 15 inch SXGA...
LCD Screen turned opaque at two places, I see two white opaque lines 3 inches wide one on left side of screen and other in the middle
Yes you are correct. I would say 95% of the time, you will need a LCD screen replacement. Also be sure to disconnect and reconnect the lcd cables, at the motherboard and behind the lcd itself, just to make sure the cables aren't making bad connection.
I have provided you a link to MANY lcd screen for your laptop on EBAY.
http://computers.search.ebay.com/Satellite-P100_Screens-LCD-Panels_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ31569QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
Hope this helps you. Please rate my solution.
May 16, 2009 | Toshiba Satellite P100 Notebook
Hp Pavilion dv1000 Black screen
It is either the inverter board or the bulb
If it looks pink in color than it is the bulb and that can be quite the intensive project to replace
If it is the inverter board than that is not so bad and you can pick up an inverter board on eBay usually for around $10 to $20 and that usually installs right under the LCD screen (usually screwed to the LCD screen)
The inverter board is what powers the light bulb the data cable is totally separate function.
If you can see data on the screen with a flashlight but there is absolutely no light coming from the screen at all ever than it is probably just the inverter board
But there is a possibility that you could order the inverter board and have it turn out to be the bulb and if that is the case then unless you are very comfortable taking apart laptops then maybe a new screen would be best since you practically have to take apart the LCD to change the bulb.
But screen cost around 100 to 150 on eBay so if you decide to do that then might as well try for a deal like this: (I just spotted this on eBay and it is for entire new top half of laptop with glossy screen and inverter board wire harness and all for the same price or less than just the screen http://cgi.ebay.com/HP-dv1000-Pavilion-14-1-BrightView-Glossy-LCD-screen_W0QQitemZ310102538774QQihZ021QQcategoryZ31569QQssPageNameZWD1VQQrdZ1QQcmdZViewItem#ebayphotohosting
That is guaranteed to solve your problem for sure.
Nov 24, 2008 | HP Pavilion dv1000 Notebook
Front panel usb
Step 1: Decide weither you have one or two USB cables joined together, it should look like a 4 PIN header.
Step 2: Get your manual from ECS: http://www.ecs.com.tw/ECSWorldWide/Index.aspx?MenuID=0&LanID=9
Step 3: Install the 4 PIN header the right way +5V, - DATA, + DATA, GND on the motherboard, refer to the manual if you get stuck.
Oct 26, 2008 | EliteGroup ECS P4M800-M Socket...
ECS Elitegroup lcd screen turns black after the unit is switched on after a time
It would be either the backlight behind the LCD or the inverter board capacitors going out, my suggestion buy a new LCD screen.
Mar 08, 2008 | EliteGroup ECS A535 Notebook
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
MSI MS-1012 Notebook Logo
136 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
