Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
Oven door came off. how do I put back on? - Whirlpool Accubake RF362LXTT Electric Kitchen Range
    President:
  • 1,273 Answers
Hi, W/D here.
Open the hinges about 30 degrees, and open the locking latches that are on the hinges. Slide the door on the hinges and set the locking latches. Done!
--W/D--
Posted on Apr 01, 2011
Oven door closes but does not fit snugly against the face of body of oven. have taken door out and put back in/on with no joy, owner of oven thinks it has been like this since new.
It is like that on the bottom, of my own door of my oven.
Since new! On the older oven I had, you lifted the door and it's hinges up and out and the door came off to make the old way of cleaning the oven easier - when you put it back on, the door would pull up tight on all sides - new ones' seem to have a gap
Mar 12, 2015 | Ovens
FIXING DOOR (DOOR IS COMING OUT)
The large oven door pull's off , and can also be pused back on the same way , if holding the door about 12" from closing pulled towards you to remove or push down to put back on if you pull it off the hinges it may take two to put it back on again
Jun 08, 2011 | AEG B2100-4 Electric Single Oven
How do i put the oven door back on after i removed it to obtain measurements. now i can not get the door back on
I had the same problem today I found that you have to extend the hindge enough to have the lock tabs lock into the door to hold the hindge in the extend mode. If the tabs are not back in the door it will continue to snap back. After you lay the door in place be sure to extend the lock tabs back up into the oven side towards the pins that you hindge lay on. WATCH YOUR FINGER TIPS!!!
ken@mobilevapor.com
Nov 14, 2010 | Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I can't remove the door on a whirlpool oven model RBS305PDB
I removed the oven door without putting in the door removal pins that I was supposed to use. Now I can't put the door back on.
Oct 22, 2009 | Whirlpool RBS305PD Electric Single Oven
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
157 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
