Question about Philips 42PF9631D 42 in. Plasma Television
Blinking 7 times took off rear cover do not see any blown caps or dark spots whats next trouble shooting step
  • Philips Master
  • 8,457 Answers
The main Tuner signal board is the causes and the problems.That the board where it take in the incomming broadcasting signal wire plug into it.Try website like Ebay.com to buy a refurbish Tuner signal board for the replacement.
Posted on Apr 01, 2011
  • mfmiller899 Apr 01, 2011
    is there anyway to test before just changing parts?
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
My servie engine soon light is on and sometimes blinks. I took it to AutoZone to check for a code and their machine code reader thing would not come on. What does that mean? I also took it to a sevice...
Even a loose fuel cap or distributor cap can bring up the light . Without codes it will be like shooting in the dark to identify why it is light up. Any fault , anywhere in the car can cause the engine light to come on.
Unless you face any problem in your car dont break your mind over that.
May 29, 2010 | 2000 GMC Sonoma Extended Cab
Mitsubishi blinking green light of death
I just replaced the 4 caps on my WS-65513. I had some trouble w/ getting the board back in (and out for that matter). I took my board to a local repair shop and had them do the soldering. But when I got if back I had some trouble getting the board to line up right, it would work sometime then go back to the blinking. So you might try adjusting the board to make sure that it's lined up properly in the slots. Mine looked like they were, but every time i'd put the screws in the hold it down it would move the board maybe a 1mm and it wouldn't work.
Dec 31, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Goodman GMP075-3 heater blinks continuously,
Most all of them furnaces trouble shooting sheets located with the wiring diagram . Count the number of time it blinks and look at it on the guide it will tell you whats wrong
Dec 05, 2008 | Goodman GMS80903BNA Heater
Blinking green light
depending on the severity of the caps there are two fuses on the DM that could be blown.
Sep 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Hitachi 50UX26B/27K 50 in.... Problem
Good Day, papamotts;
Won't turn check Q912, Q914 & I901. No relay click check Q003. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
7 blinks followed by 8 blinks
The buzzing sound you hear is typically the FBT shorting out when you turn the TV on. If you open the back panel and watch the FBT as you try to turn on the TV you can see it shorting out. It will be obvious.
Jul 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Green light will not stop blinking
often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
May 12, 2008 | Mitsubishi WS-65511 65" Rear Projection...
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Philips 42PF9631D 42 in. Plasma Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
