Question about Canon imageRUNNER 1310 Printer
Check Toner/Drum CRG I Replaced Both Stil I have Same Problem.Please can u tell me How can i fix This problem?
  • 3 Answers
Sounds like you need to reset your counters.
Check these areas on your printer to see if you can locate them.
To select events that will raise alarms:
1. In the navigation pane, expand the Canon Devices node and the Configuration
node, and click Alarm Management.
2. Select the check box for each type of information you want alarms generated for.
3. Click Apply.
Specifying Rates and Timeouts
To set rate and timeout values:
node, and click Rates and Timeouts.
2. In the Discovery Refresh Rate list, click how often the client should refresh the
navigation pane's list of discovered devices.
3. In the Alarm Poll Rate list, click how often the client should poll for alarms.
Posted on Apr 01, 2011
Print copies have a grey cast. i replaced the toner cartridge holder but am still getting a grey cast. i have been using off brand toner replacement through amazon. i hope this can be fixed.
it can be that the drum cleaning blade is poor quality or charge roller fault. To avoid the low quality repair of toner crg's and possiblle troubles related to repaird crg burst, use only original supplies or buy from verifed toner remanufacturers!
Sep 15, 2011 | Brother DCP 7010 Multifunction Laser...
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
Jan 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Dark copies
First remove toner crg and check the drum, if its covered with stripes or toner, replace toner crg.
It also could be fixing film fault.
Nov 16, 2010 | Canon imageCLASS D320 Digital Copier
My MF8180C is asking to replace the K cartridge, and I have bought a 301 toner cartridge but the printer has a drum cartridge instead. How do I replace the black toner into the drum cartridge or do I have...
the toner crg is located in front of copier, the drum is separated from toner and it removes if you open upper cover.
If the copier ask you for toner open front cover and replace toner.
You do not have to replace drum if the copier doesnt tell you to replace.
Jul 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
Canon Super G3 Laser Classs310 all in one. Has lines in copies and when receiving faxes and sending faxes. How do I resolve this problem?
Check toner crg. if there are streakes on drum change toner crg.
If not there is problem with fixing system.
Jun 07, 2010 | Canon Office Equipment & Supplies
Hi. Everytime we use a new toner cartridge in our UF590, it works for so long and then has a paper jam evertime it tries to print a fax.
When did you replace the toner crg?
It may be that drum isnt turning, and when paper comes to the drum it jams.
New crg should resolve the problem.
But you also want to check the pick up, feed and separation rollers.
Jun 02, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
'check toner/drum crg' error, Cannon imagerunner 1370f
check the contacts inside of copier cavity where they line up with drum unit and make sure they are in correct position.
Mar 01, 2010 | Canon ImageRUNNER 1670F Copier
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
Canon imageRUNNER 1310 Printer Logo
580 people viewed this question
old marine
old marine
