Question about JCPenney Gyropter RC Helicopter
Hello, I bought 3 channel IR Gyro helicopter (gyropter last week in JCPenney in Orlando but I didn't test and now I am back to Brazil and executed the steps to charge and tried to start flying but the helicopter cannot rise up. In all the tests the helicopter fall down on left or right and it is impossible rise up. I tried to move the throttle up to increase the speed of the main rotor and the helicopter cannot rise up. When I open the package I realised that stabilizer had only one propeller connecting rod on the upper properlier, is that correct? I connect other spare part in another rod and try to start fly but the same problem happened. Pls, Could you help me to try fly and rise up the helicopter? Thanks, Cido
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
  • 76 Answers
SOURCE: do you have a manual
u can get it from internet
Posted on Dec 27, 2010
caroldon
  • 17130 Answers
SOURCE: Hi I have a gyro
Make sure that the balancer wheel/rotor at the rear is not damaged while it had the fall/hit.
If so make sure that the tails is rectified. Once the rear is damaged the helicopter stabilizes on the movement of the rear rotor as the top main rotors need a counter balance.
So it is possible that this mechanism is damaged and must be recitfied.
Posted on Dec 30, 2010
SOURCE: My parents bought a Propel
I solved this same problem by removing the canopy and realigning the helix shaft with the motor gear. The small screwdriver provided will work. Be careful of the front white LED light when pulling the canopy off.
Posted on Jan 11, 2011
SOURCE: How to change channel/band for
1. Switch the controller to the desired channel. 2. Turn on the helicopter you want to control. 3. Move the joystick forward and back until the rotors start spinning.
Posted on Aug 28, 2011
My helicopter is not turning on after it fell down and the charger is full.
Hi make sure you are on correct channel. Usually there are A B C channels. Look on your heli and try each one :)
Jul 20, 2015 | JCPenney Gyropter RC Helicopter
Brand new and right out of the box, the bottom blades do not spin at all.
The Jcpenney ones seem to have the most problem with this. Some of the gears might be out together wrong, see if Jcpenney will take it back.
Chaio!
Nov 16, 2013 | JCPenney Gyropter RC Helicopter
Gyropter RC helicopter replacement parts
Replacement parts can be found on amazon, take a look: Amazon com Gyropter RC parts. I hope this was helpful. cheers
Jan 26, 2013 | JCPenney Gyropter RC Helicopter
I need the instructions Manual for a gyropter. Can you send it to me?
Look online for a manual. Searching "Propel Gyropter Manual" Should bring up at least a pdf manual.
Chaio!
Dec 30, 2012 | JCPenney Gyropter RC Helicopter
Need an instruction manual for a Gyropter R/C, 3-channel helicopter
Hello
Couldn't exactly find the manual but,here's video tutorials you might want to have a look at:
http://www.youtube.com/watch?v=i2zWi4lMxxk
Hope it helps.
Ken
Jan 26, 2012 | JCPenney Gyropter RC Helicopter
The gyropter will not charge when I plug it in
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Aug 14, 2011 | JCPenney Gyropter RC Helicopter
My parents bought a Propel RC 3-Channel Remote Control Gyropter for christmas like a month ago at JC Penney. When I tried to make it fly I noticed that the lower helix was not rotating. So I have not been...
Dec 27, 2010 | JCPenney Gyropter RC Helicopter
JCPenney Gyropter RC Helicopter Logo
219 people viewed this question
Top JCPenney Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a JCPenney Toy Expert? Answer questions, earn points and help others
