Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
When replacing double stack drive/deck pulley,how do you keep it from scraping deck/20 hp,46 cut,02 model,yard machines??!
    Novelist:
  • 111 Answers
MTD part number 950-0960A This is a spacer that goes under the pulley stack. It should help to keep the pulley from rubbing on the deck. Hope this helps.
Posted on Apr 01, 2011
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
How do you unstick idler pulley on craftsman lt1000 riding mower
do you mean stuck as in the pulley doesnt turn? or stuck as in the arm that the pulley is attached to will not pivot? if its the pulley, replace the pulley. If its the lever, you will probably have to clean dirt or debris from between it and the cutting deck.
Jun 08, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
I have a Husqvarna tractor. I recently have noticed that when cutting grass it wants to pull slower than normal. It does this sometimes when making a turn it will just stop, then take off at much slower...
1) Gear shift transmission or Hydrostatic?
2) check condition of the transmission drive belt, pedal tensioner spring, idler pulley bearings, engine stack pulley groove
3) if it is a hydro, check the above plus * make sure the brake caliper located on the transmission is fully releasing. It can drag, and overheat the transmission.
4) Tractors that have the battery under the seat: the battery leaks as it gets older, and the acid drips on the brake caliper and seezes the actuating pins and makes the brake drag.
Nov 03, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
I have a Craftsman 20 HP 42" Mower. I replaced an idler pulley and drive belt on the mower deck. I got the deck reattached to the mower but now the mower blades spin even when not engaged. How can I fix...
Did you obtain the correct replacement belt AND pulley. Double check your part numbers against the parts list for your machine. If you verify that they are correct, double check the belt routing, make sure it didn't get on the wrong side of a belt guide and is in the correct configuration. Look at your idler pulley and make sure the release spring is doing its job pulling it back from the applied position. Make sure that the arm for the pulley moves freely where it is bolted to the deck, it could be bound up with rust or debris. You should have a lot of slack in the belt when it is in the released position. If it does not then either it is the wrong part or improper installation
Sep 17, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Yard Machine tractor drive deck belt failure
i need a diagram of tensioner springs on yard machine deck 1998 42inch
Aug 11, 2009 | Yard Machines Red Edger
Have a 46 in deck need to put the belt on i forgot how it go on the deck
Go online to your mowers site and they should have the proper belt and pulley positions for you.
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Deck belt keeps tearing up then falling off
If it's an idler pulley, where the belt changes direction from the engine - yes it should turn freely. If it's a double pulley where the drive pulley from the engine connects with the deck/blade pulley, then it it's not going to turn totally free because of the blade pulleys connected to it. But in all cases, none of the pulleys should be seized. Try using WD40 or PB Blaster on the pulley bearing surface to loosen it up - or a new pulley...
Jun 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The mower deck doesnt stay kicked in
1) check condition of deck drive belt
2) check condition of belt tensioner system located on top of the deck.
tensioner system pivots and also applies brakes on spindles
being worn, it does not give full travel to tension the belt
3) make sure engine mount bolts are tight
4) engine 'Stack Pulley' groove can be worn
5) check idler pulley bearings
Jun 15, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
333 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
