I need a driver for my USB to serial port cable and my laptop does not have a cd to read the disk
    Novelist:
  • 120 Answers
You have at least one USB slot. On another computer you can try copying the driver CD to a USB drive, then use the USB drive to install the driver.
Posted on Apr 12, 2011
Have old compaq Deskpro EN ENS815EC733 M1BU
I would buy a cheap usb card to fit into a pci slot on the old computer.
Otherwise you would need a serial cable (if your laptop has a serial port) if not it would be a serial to usb plus the software to transfer, i would say far too much trouble.
A usb card is a couple £/$
http://www.google.co.uk/products/catalog?hl=en&q=pci+usb+port+card&um=1&ie=UTF-8&cid=13689229979239224585&ei=5RBCTMCBCIyOjAfu8eUV&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDAQ8wIwAg#
Jul 17, 2010 | Compaq Deskpro EN FC 6450+ Model 10000...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Computer says no contact with machine have tried everything
Youn don't say what Windows flavor you're using, or whether you have a serial port or not. I'm going to guess you have a laptop with Vista on it, and the laptop has no serial port for you to connect the 7570's cable.
You need to get either a serial to USB cable that works with the 7570 (read some of the posts in this section. There's at least two or three that do), or another device called a Port Replicator, that has the serial port as well as a parallel port for printing, and perhaps one or two USB ports.
In my case, I have two of the latter ones, the Targus PA090U and the PA075U, and both need no drivers with Vista and work OK. They simply get recognized when you plug them into a USB port and are available to you, except that in my case, the serial port always defaults to COM port 4.
The other reason why you may not be getting a connection may be found in your Machine Configuration, in PCD_WIN. In version 2.0, which is the one I have, go to the Machine menu option, and at the bottom, click on Configuration.
Here make sure the COM port is the correct number, and then set the speed to LOW. That works for me.
Aug 23, 2009 | PfaFF Creative 7570
Need a USB converter for some serial thing
dynex puts out a usb to serial adapter can be bought at best buy for somewhere around 15.00 you will need the drivers from the cd to make it work and then will probably have to set the port it is looking for that should be all you need
Dec 05, 2008 | Toshiba - Floppy disk drive - external -...
Format
you need to go in to the bois and click on the boot up menu then the 1st boot should the usb then it will pick up your xp disk
Nov 19, 2008 | Dell Latitude C400 P3 Notebook
CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Computers & Internet Logo
1,267 people viewed this question
David Payne
David Payne
