Question about Jenn-Air JGW8130DD Gas Single Oven
Only certain numbers on my control pad work. I can hit bake twice and the oven will heat to 350 and thats is far as I can get.Can you please tell me what to do . Thank you Justin Kiernan
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Posted on Dec 30, 2007
  • 408 Answers
SOURCE: Oven will not heat
Sounds to me like your bottome element is burned out.  I would replace this, or at least take it out and bring it to an appliance store to have it tested.
Posted on Mar 04, 2009
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
ginko
  • 19396 Answers
SOURCE: F0 fault code
Hi ,
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
Posted on May 29, 2009
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Mar 07, 2015 | KitchenAid Ovens
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
F7 and then clock is lit up. The key pad for upper oven is locked. I can'tget it to do anything. Before this it came up bake at 350 degrees and push to start. I did this, even I didnt want oven on. I also...
OK, this code is signaling an issue concerning the key pad or control board.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 14, 2009 | GE JKP27 Electric Double Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
Temperature in oven is way off
Jim,
A couple of questions... What makes you think the oven is off that far? If you have a set on the shelf dial type thermometer, throw it away. They are never accurate and generally read 50+ degree too low. I recommend the "biscuit test". Which is simply a cheap can of "hit on the edge of a counter top to open" biscuits and see how they bake with the instructions on the can. Make sure you allow the oven to preheat for 20-30 minutes (always but especially for this test).
To change the oven setting press BAKE, then run the temp up to 550 then immediately press and hold the bake pad for 10-20 seconds. The display should read 0 (zero) you can then use the up down arrow pads to adjust, hit bake pad again and then "clear" when done to lock it in but, you can only go up or down 35 degrees. If it is truly off by more than that you would need to change the main oven control board and oven sensor.
Dec 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn-Air JGW8130DD Gas Single Oven Logo
35 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
