Question about Magellan Maestro 4000 GPS
I need a new power cord for the power outlet in my vehicle. How do I order the part?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
There are several vendors on Ebay that will sell you the item you need. Since you have the make and model of your GPS it wont be hard to find the cable you need and Im sure it will be much cheaper then buying it from the manufacturer.
I hope this helps you out.
Posted on Apr 01, 2011
I need a vehicle power cord for my dashcam uniden 945
JAYCAR or similar electronic shop have a range or plugs that will fit
Jun 05, 2016 | Cars & Trucks
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Sep 18, 2010 | Sunbeam Vacuums
My garmir street pilot 2720 is not powering up. what to look @ first
In order
1- Check using another device the power outlet
2- Check the garmins power cord, are the connections still firm, if they are loose and sloppy, bend the metal tangs out a LITTLE bit
also note the metal tangs in the power outlet may be bent in from continued use bend them into towards the centre of the plug NOTE PULL THE RIGHT FUSE ON THE VEHICLE BEFORE BENDING OR STICKING ANYTHING INTO THE HOLE TO ADJUST THE TANGS
3- In the end that you plug into the cars power outlet is a 1 amp fuse, is this still good.
4- Does it work in somebody else's car
May 10, 2010 | Garmin StreetPilot 2720 GPS Receiver
HP 4250n has no power.
The first thing you should do is make sure the outlet you are plugged into is getting power. Then check the power cord -- either with a multimeter or by swapping it with a known good power cord. If the outlet and the cord are both good and you're not getting any power to the printer, the most likely option is a bad power supply unit. Maybe an electrical surge or spike fried something on the board, or maybe it just went bad over time. You can order a new one from HP or from an HP authorized reseller.
Hope that helps
Jan 11, 2010 | HP LaserJet 4250n Printer
Our compact refrigerator has stopped working.
Does the compressor run at all? If not check for power at the outlet by plugging in a working lamp, check the temperature control, (IF) you are capable, unplug the cord, remove the cover where the control knob is. remove the control from its mounting, connect the two main wires together. Then plug in the cord to the wall outlet. If the compressor starts and runs and the system cools your control is bad and you need to order a new control.
May 16, 2008 | Haier Refrigerators
Magellan Maestro 4000 GPS Logo
26 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
