Question about Milton Bradley Bop It
My bop it stopped working. i tried to change the batteries, it didn't help and the instructions are missing. it is the white edition with the green switch that lets you shout it as well.
How do I get instruction manual for Hasbro bopit carabiner edition
Use google search and you can download the PDF from the results. This was previously answered for you.
May 20, 2015 | Hasbro Bop It Mini Carabiner Edition
Bop it tetris
Well, did the previous batteries explode? If so, you'll need to clean it out with rubbing alcohol (just the battery contacts) or switch the batteries around, you may have them in backwards.
Dec 27, 2013 | Hasbro Bop it Tetris Game
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
My lg tv suddenly stopped working with the remote? Didn't change anything. Just woke up and the remote would not work. Changed batteries but no luck. Tv works but remote no longer works with it
Visit this site. Type in the site name "Electro-help" in yahoo search box. Pull up older posts there. You will get all details. Codes, setup proceedings etc:-
Jun 09, 2012 | LG 32LG30 32 in. LCD HDTV
I want to reset bop it bounce
hi, try and remove the batteries, thats how the other bop-it products reset.
good luck!
Feb 02, 2011 | Hasbro Bop It Bounce Game
Instructions for bop it when it makes a weird noise
After you get past novice level (Score > 100), instead of spoken instructions, sometimes you get sounds instead of the spoken instructions."Crash" sound means press Bop It"Ratchet" sound means "twist it""slide whistle" descending sound means "pull it"There is another sound for "shout it" if you have this feature active.
Dec 26, 2010 | Hasbro Parker Brothers Bop It
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
The instructions for the Bop it was thrown away with the Xmas wrapping paper Can I get instructions on line how to continue to play after reaching 100?
just go on bop it hasbro just type in bop it instructions and hasbro bop it should show up then click demo and then unlock it then go on exper level and look at the tpo and it says it
Jan 02, 2010 | Toys
Milton Bradley Bop It Logo
196 people viewed this question
Top Milton Bradley Toys Experts
Adam Fjeld
Adam Fjeld
Are you a Milton Bradley Toy Expert? Answer questions, earn points and help others
