Question about Jl Audio 250/1 Car Audio Amplifier
Subwoofer a steady loud pop pop pop sound please help
  • 3 Answers
Check your earth cable. Connect your earth (black) cable elsewere.
Posted on Aug 06, 2008
Advent subwoofer
emits a steady sound means that their is some miss connection in the in put
May 23, 2014 | Audio Players & Recorders
Loud popping sound came from my powered sub now no sound
Did you have your power on when you plugged anything in if so h could have seized your magnet for fried your voice
Aug 11, 2013 | Infinity BU-120 Subwoofer
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
I have a Sharper Image Powered Subwoofer SA251 and it started making a steady harmonic loud sound, turned it of and on and still had the same problem. I also unplugged it and pluged it back in and still...
Subwoofers are basically single mono amps. In your case it could be caused by a faulty electrolytic capacitor or a defective power output device.
If you can't do the job yourself, then any decent electrical service shop should do it for you.
Nov 27, 2017 | Sharper Image SA251 Subwoofer
15 inch velodyne subwoofer making a loud popping sound
If you have changed the signal source, then these may not be the problem at all, it may be that you have the sub output set to low on your processor.
This may be one of these problems.
It could be the "auto on" circuit.
If you change the switch on the back of the unit to always on does it still do this? if not then it is the auto on circuit that is the problem.
The driver mounted servo unit is starting to fail.
A cap in the amplifier input section may be going bad.
You nwill need to contact Velodyne for repair of the unit.
Feb 20, 2009 | Velodyne HGS-15 Subwoofer
Car audio sub issue please help
did u cross any wires when putting back check rca cables
Dec 20, 2008 | Hifonics Brutus BX12D4 Car Subwoofer
HTS3440 Philips No Sounds from Subwoofer
check the wire connections....and check the settings in the player..
Nov 08, 2008 | Audio Players & Recorders
Loud steady sound when turned on
If it's a humming noise you are describing, then it may be that one of the power supply filter capacitors has failed. Of course it could be some other sort of power supply problem as well.
Dec 14, 2007 | Wharfedale PowerCube PC-12 Subwoofer
Getting a loud " POPPING" sound
Switch the wires on the two speakers at the box and see if the problem moves to the other speaker. If the second speaker starts popping and the first one stops, the problem is in your amplifier. If the same speaker keeps popping then you probably have a blown sub.
Mar 01, 2007 | Rockwood XR-1712 Car Subwoofer
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
Jl Audio 250/1 Car Audio Amplifier Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
