Question about Goldstar KG6000R Window Air Conditioner
I've had my unit for about 3 years and it does not get cold enought . what cani do to fix my problem
  • Goldstar Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Apr 01, 2011
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
The unit runs but does not collect water...it just runs. I've left it on for several hours. In the meantime, my basement is very moist with a lot of humidity from all the rain we've had. Even my...
the units low on refrigerant or freon,its normal for these to lose their charge after 2-3 years of use,i repaired a lot of these over the years,a couple of B.P.V.'s and about 9 ozs. of whatever type of refrigerant or freon and they will go another couple of years, all for about $50.00
Jun 01, 2011 | Kenmore 54501 Dehumidifier
My furnance (Amana 90) will not work when it's extremely cold outside. I have checked and replaced the flame sensor. I've checked the pressure switch. The furnance is a champ at all times other than...
Since it only does this in extremely cold times is there any chance that your drain line from the condensate drain is passing thru a space cold enough to freeze it. Good luck and thank you.
Feb 23, 2011 | Heating & Cooling
Kenmore not cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
A\c unit
it cold be different problems.
1-check for any air leaks around the house.
2-check the return box and see if have any opening and seal the holes.
3-check the insulation on the attic or any motor that takes the heat out the attic.
4-check if the unit is under tonage each tonage mean a 400 sf per ton.
5-check if the air handler coil is not dirty and enought air going thru the coil.
6-check the pressure of the condenser unit if have the rigth presures.
7-check thermostat if is set-up right.
Jul 22, 2008 | Heating & Cooling
Cooling problem
Check your unit for dust buildup or blocked filters. Clean as required.
Jun 14, 2007 | Fujitsu 12C1 Air Conditioner
Goldstar KG6000R Window Air Conditioner Logo
82 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
