Question about TurboChef TORNADO Electric Oven
The oven not holing the hit - TurboChef TORNADO Electric Oven
    New Friend:
  • 107 Answers
Does it reaching to optimum temperature or its not getting the ready screen.
It under warming situation.
then it might be IR element or convection heater.
let me know if you know how to use volt meter.
then I can explain you in detail how to troubleshoot
thanks
please rate my work
Posted on Sep 03, 2011
New element touching bottom of oven. Two small holes in over.
The element should not touch the bottom of the oven. I would call up the person that did the repair and tell them about the small holes. This may be a fire hazard. You should not be charged for work that was done improperly.
Oct 28, 2015 | Ovens
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
Back right hotplate getting hot when oven on
That hole is most likely a vent for oven where some heat escapes.
Nov 10, 2017 | Hotpoint Ovens
Heatman, please help: Bake burner cuts out
Try cleaning the pilot nozzel with compressed air. I had the same problem with my fireplace.
Dec 09, 2012 | Ovens
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
How to patch hold in electric oven?
use some high heat two part epoxy let it set up just a little and then plug the hole. you can use titainum putty at a bering supply store but it's expensive but is a good fix.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
Oven igniter does not light unless hit
you can check you connections to see if loose wire nut.normaly people will say they hit the oven safty valve and gas will come out.the amp draw on that ignitor is as ive been taught 3.2 to 3.5 if low than that it will have a hard time opening the safty valve.ive sold and installed 100s of ignitors and a few valves.hope that helps.god bless tom
Jan 03, 2009 | Magic Chef 9512 Electric Single Oven
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
TurboChef TORNADO Electric Oven Logo
71 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
