Question about Cycling
I am borrowing a bike from a friend and i can not figure out how to change the gears...
    Brigadier General:
  • 8,546 Answers
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Posted on Apr 01, 2011
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I am borrowing a diamondback
Each control is binary - harder to shift in one direction, easier in the other.
Google "how to shift a bicycle" for videos
Posted on May 28, 2011
My harley road king 05 won't start. I've already replaced the battery, when I switch on the ignition I do hear the fuel pump and see the oil like light on the speedometer turn on, but when I press the...
The overrunning clutch (starter gear) is defective or the bendix is not engaging the starter gear on the clutch shell. You will need to remove the outer primary cover and the starter to replace the bad parts. You will need to diagnose whether the solenoid, starter clutch or bendix is the problem. That way you don't buy unnecessary parts. I'd try borrowing a known good solenoid from a friend first, then dig into the primary if the solenoid does not solve the problem.
Feb 07, 2015 | Harley Davidson Motorcycles
How do I get the gears to work again on my Schwinn Mesa GSX Mountain Bike?
The shift cable is likely too loose, but there are multiple items to tighten, lubricate and adjust on just the derailleurs, let alone the rest of the bike, before it's safe and ready to ride. I would suggest you get some assistance from a more knowledgeable friend, a bike co-op or a bike shop.
May 18, 2017 | Cycling
My 2004 yfz 450 wont start i changed plug and stator still wont start you can hear lil backfire from pipe when trying to crank
Did you tried replacing the CDi for your bike?
Tell me what happen when you replace or borrow a CDi from your friend, just to check if it is the real culprit......
Sep 30, 2011 | 2004 Yamaha YZ 450 F
My bike dosent change gears its stuck in nutral its a 79 ironhead i just cant figure it out
Rock the bike backwards and forwards while trying to shift the gears. If the lever moves up and down but the transmission does not shift, the shifter shaft in the transmission may be broken. When doing this test, make sure the final drive chain is on the bike.
Good Luck
Steve
Jul 21, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Bought a Huffy 26inch magellan 700c mens commuter Bike from Kmart there was no manual having trouble figuring out how to get it into various gears, is there a manual I can down load.
just move the gear levers, but keep pedalling forward while you do. you cannot change gears while the bike is stationary and do not pedal backwards while changing
Apr 06, 2010 | Huffy Newport 26 Men s Comfort Bicycle
How many rpms should i go on my honda cbr 600
hi,i dont know a lot about this particular bike,but,as with any high revving sports bike you will need to keep the revs up before changing gear,an 883 sportster has a lot more torque than your bike and you can "short shift "them and let the torque do the work,however on a cbr i think you will need more rpm before you shift as they dont have the torque of your old harley,a friend of mine has an r6 yamaha,that thing revs out to nearly 17000 rpm he doesnt change untill about 9 or 10000 rpm,from memory your bike should be capable of nearly 60mph in first gear..hope this helps...cheers
Mar 10, 2010 | 1997 Honda CBR 600 F(3)V
I borrowed my friends 2005 vstar 650. I was
sounds major. Clanking and low on oil sounds like a broken piston ring. Suggest dealer check with compression tester rear cylinder. Replace v star with Harley if necessary.
Sep 19, 2009 | 2003 Yamaha V Star Classic
Bike turns off when I put in 1st or 2nd gear
First replace the clutch,clutch basket,and throw out bearing that has been destroyed,check the cable for damage and if you still have the same problem,Then check the kick stand switch.
May 20, 2009 | 2000 Suzuki GSX-R 750
1994 rf900
I have the same problem. Mines from an over-tightened chain. What caused yours?
Mar 22, 2009 | 1994 Suzuki RF 900 R
Cycling Logo
100 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
