Question about Refrigerators
My ice maker in my Whirlpool side by side (model ED5GHG) works fine other than the fact that it drips water every time I drop the arm to make ice. I had to take out the factory ice bucket because it was giving me a block of ice instead of ice cubes. What could be causing this drip and how can I fix it?
    Sergeant:
    Champion:
  • 202 Answers
Hi.... sounds like you have a bad water valve at the back... thats the only thing that controls the water
Posted on Apr 01, 2011
We have a side by side whirlpool ice/water though the door water yes,but no ice production model number ED5SHAXMB10
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 11, 2011 | Whirlpool Refrigerators
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
No longer making ice
Hello, Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Thanks
Jul 12, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My whirlpool model # ed2chqxkb05 is not making ice, we can still use the water in the door. its not making ice. Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker quit working but water side works still.
Sep 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Side by Side Ice maker not making ice.
Aug 31, 2009 | Whirlpool GS6NBEXR Side by Side...
Hi. I have a Whirlpool sise by side gold
Aug 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana ARS2665AW side by side ice maker not filling
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
