Question about Super Flower Computer Super Flower Cable 500w Power Quad Fan Power Supply (TT550K04) Power Supply
Problems with P35neo2
Hi every body,
I am using Sunflower 550W with Main board P35 Neo2.I got this problem and appreciated to get any suggestion from you to fix this problem.
When I turn on my desktop, within 3 seconds, all the LED signal turns red (LED 10, 17, 18, 19 and 20) then the CPU shutdown. I believed when these red signals form LED because there was something happen with my processor (either damaged or wrong installation). But my Processor is the new one, bought 1 week ago and I installed correctly.
However after 2 or 3 seconds, my CPU automatically turns on, then work as normal.
I suspect my main board required 8 pin for mobo powers, my power supply system only have 4pin for mobo power.
Can you give me an advice to fix this
thank for reviewing
  • 781 Answers
Check your M/board manual for setup if it should have an 8 pin power connector you will need a power supply to suit it if you continue trying without it you could also be up for a new motherboard and CPU
Posted on Aug 08, 2008
Msi p35 neo2 supports boot from pci express with revodrive 24ogb ssd?
Hello here is the home page:
http://www.msi.com/product/mb/P35-Neo2.html#/?div=BIOS
Why not connect to the sata drive ports ??
I have not heard about booting from pci express.
Pci express is a screen card slot.
Jul 07, 2013 | Computers & Internet
What vitamin is in sunflower seeds?
Sunflower seeds contains various vitamins, like:
a. Vitamin A
b. Vitamin B
c. Vitamin B1
d. Vitamin B6
e. Vitamin B12
f. Vitamin C, and much more.
Apr 17, 2013 | Cooking
I was wondering if my pentium dual core E5700 would work in a msi p35 neo2??
It should work just fine - The Pentium E5700 is an LGA775 and so is the MSI P35 Neo2.
However, installing a processor into a motherboard is a bit more complicated than simply plugging it in, so I would consider having a professional install it for you.
Sep 16, 2011 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Hangs on testing base n extended memory
appears to be a RAM/Memory Problem.
Or Corrupt Bios.
Try swapping The Memory to different Slots, or try 1 stick in Individual Memory Slots. Also Ensure the Board Has the Correct Ram Installed i.e DDR/DDR 2 et,c.
Mike @ Compurepair.
Nov 06, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Msi P35 Platinum motherboard bios problem with the latest bios 1.10. I want to put an oldest version, the 1.9 but i don't find a solution...
Flash the new bios and replace with the old one. The same thing you do when you update the bios of your motherboard.
Oct 27, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Hello please help i wanted to update bios for motherboard MSI P35 NEO2 and i didnt made a backup on a flopy disk (atleast i think this is the problem). Now after the computer restarted i get the message: I...
It seems to me that if your BIOS are not damaged, you can still make the copy and proceed as per procedure. Thank you for your consideration and choice for our service! My name is Constantin (arzconst is my internal nickname under Fixya.com).
Jun 19, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Msi p35 neo2
take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Jul 02, 2008 | Intel Motherboard
Problem with motherboard MSI P35 Neo2-FR
suggest not, if you really wan try, go ahead, but i suggest not.
Jun 05, 2008 | Intel Motherboard
P35 Neo2 fails to power up
try to clear cmos here is the way if u dont know:
get to the jumper next to the mainboard try to change its position for 3 seconds then put it back to its normal position.
start the computer , enter setup and save defaults.
May 26, 2008 | MSI Computers & Internet
Super Flower Computer Super Flower Cable 500w Power Quad Fan Power Supply (TT550K04) Power Supply Logo
112 people viewed this question
Top Super Flower Computer Computers & Internet Experts
David Payne
David Payne
Are you a Super Flower Computer Computer and Internet Expert? Answer questions, earn points and help others
