Question about Garden
I am trying to repair a broken switch on a craftsman compressor the electric motor is model number is 91916415
  • amberjason Apr 01, 2011
    Hi Kelly,
    Thanks for getting back to me. I am not sure how to tell the difference between the pressure switch and the start switch. The on and off switch is 2" that turns the pump on and off. There is a pressure relief valve that I can manually pull and air will escape. Does this valve automatically come on if the pressure gets to high? Before the on off switch broke the compressor would turn off automatically when the pressure got to the right level. Now I am not confident that it will turn off.
    Hope that helps, Scott
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
I am trying to sort out which switch is broken. Is it the Motor start switch (Centrifugal) or the pressure switch?
There is this switch: ( item 24 / $85.99 )
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919164150/0247/0703000/10055097/00001?blt=06&prst=&shdMod=
If it is the centrifugal start switch I need to know a lot more about this motor. There has to be another data plate on it with different numbers. I need all of the numbers you can locate on the motor. Note the motor itself is "no longer available."
Kelly
Posted on Apr 01, 2011
  • Kelly
    Kelly Apr 01, 2011
    Hi Scott,
    All aircompressors by law must have a "High Pressure Relief Valve" and most of them are set some where beween 150 and 175 Psi. The reason they all have this valve is that in case of a pressure switch failure you do not rupture / explode your tank. When they actuate it will get your attention quick. Trust me you will know when it opens.
    From everything I am reading and all the research I have done the switch (Item 24) of the link in my first response is an all in one switch that includes the on / off switch and the pressure switch. It appears that there is also a line pressure release in the switch assembly so that there is not too much head pressure on the pump which enables the motor to start when the pressure switch is telling the motor to start. I.e it prevents the motor from burning up.
    I downloaded the owners manual and it was useless in trying to get detailed view of the switch. You would think a manufacturer would at least show a picture of the operating controls in their manual.
    I personally would not be comfortable operating the pump if it is not automatically cycling. You could install one of these switches:
    http://products.schneider-electric.us/pr...
    It would just be a matter if connecting the power cord to the switch and the motor wires. I would NOT remove the old switch as it still functions to relieve head pressure for motor stating. (mechanical) yet, you can electrically isolate it and install a new switch. You would have to do some creative 1/4' tube plumbing to install the new switch but it can be done.
    If you want it fixed right... the $85.00 on / off / pressure switch is the only option.
    Kelly
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
I can't find a replacement capacitor for my air compressor.
Hi you have to bring the old capacitor to a electric motor shop so they can match it up or write the name and numbers off the motor and give it to them and I am sure they should be able to match one up.
Mar 10, 2011 | Craftsman Air Tools & Compressors
I flip the switch and the compressor just humms for a few seconds and then it stops. I does not kick on at all. I recently roofed my house and it it did this a few times and then kicked back on. could...
Hi, ALL WAYS UNPLUG THE POWER.
The humming may be the motor itself, or a deficient capacitor.
I suggest taking several pictures of the suspected parts, before anyattempts to fix/replace them.
1- 90% of the time, the most frequent problem is the "starterCapacitor" going bad. It is a metal uncased capacitor, normally attachedto the electric motor. They have a sears number to reorder, and you can replaceit yourself, just unplugging the connecting wires and plug them to the new one.Any electronic place that sells parts may be able to sell you a replacementCapacitor cheaper than Sears.
2- It could be the electric motor itself going bad, if you have low voltage. Ifinstead of 110V you normally have 92Volts, after many times, it burns thewinding coils. Try this: UNPLUG THE POWER AND KEEP THE STARTERSWITCH OFF. Spin the electric motor by hand (you can do it rotating theBELT) about 10 to 40 degrees, this will reposition the coils. MAKING SURETHE SWITCH IS OFF, PLUG THE POWER, and THEN TURN THE SWITCH ON FOR 5SECONDS, if it won't start, turns it off. When this procedure worksmaking the motor to start, but fails again, and every time you use thisprocedure Works, you have a defective coil going bad, "meaning" thatthe electric motor have to be replaced. If this procedure works, you may beable to avoid replacing the motor till the time that it does not work anymore.
3- Also, it may be that just at that particular day, your electric grid has lowvoltage due to high demand, but next day is Okay. Try next day, or when thehigh demand is fix.
Jan 04, 2011 | Craftsman 1 Hp, 4 Gal. Air Compressor
Our craftsman air compressor 7 gallon has just quit working
hi there;
there are several reason we can consider why your compressor quit working, this due to mechanical or electrical function.trial should be done.1st trial switch off from the breaker your compressor disconnect pressure switch,connect the electrical circuit w/o the pressure swtich.direct connction the run the compressor if run, replace pressure switch.put back connection.if on 1st trial does not run the motor compressor the problem is on the motor
check the connection specially the over load protection,reset and run again.if still not runnign pull out the motor and have it repair on electric motor repair service center.then the motor is good put it back.have a nice day fix my rate thanks a lot.
May 02, 2010 | Air Tools & Compressors
Broken cog on compressor motor 919.166440
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
Nov 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 33 gallon Craftsman compressor that won't start. It's plugged in. There's power, but the switch seems to be dead. I tried unplugging it and letting it cool but it won't start up again. Any ideas?
Idea 1: your breaker/fuse is tripped/blown in the electrical panel, reset/replace and check the compressor again.
Idea 2: you may have a bad electrical cord with a break in it going to the pressure switch.
Idea 3: The pressure switch isn't closing the contacts when pressure is low. (bad pressure switch)
Idea 4: Wiring from switch to motor has a break in it. (test the at the motor for proper voltage) If proper voltage:
Idea 5: Bad compressor motor.
Oct 29, 2009 | Craftsman Air Tools & Compressors
How do i remove the air pump assembly off my craftsman 6HP air compressor, Model Number #919.152930. seems like its bolted directly to motor.
It is in fact bolted directly to the motor. You should be able to do any repairs necessary without removing the pump from the motor. I am not sure of the set up of that motor. I'm not sure if undoing that plate will also remove that side of the motor. (Something you probably don't want to do.) If you see other screws or bolts under the plate I would assume that you are safe to remove the pump plate from the motor.
Sep 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a craftsman 3.5HP 30 Gal compressor (Model
Unless your machine is worn out----it's probably the pressure switch:
A: needs adjustment
B: needs to be replaced
XYZ: head gasket leak,broken line, other air leaks?
Apr 25, 2009 | Craftsman Air Tools & Compressors
Craftsman Compressor runs Intermittantly
I have repaired many craftsman compessors with the problem that you are having. I just use the process of elimination to find the broken wire. I use a short pigtail and attach it to the motor side of the pressure switch. This will isolate the motor from the switch and the power cord. Use caution not to overfill the compressor as this will test the safety valve. If the motor runs ok then move the pigtail to the powercord side of the switch. This will eliminate the power cord. If problem is within the motor check the connectors under plate and capacitor cover. To test the capacitor you will need to find a meter with cap test capabilities or repair shop will test for free. The cap should test within 95% or printed value in (uf). If all parts test ok then motor could have internal thermal breaker that is weak. Good luck.
Jan 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Nov 15, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
