Question about Maytag SAV365ZAWW 3.3 cu.ft.
Water leaks into tub from fill spout when not in use, maybe a faulty Washer Water Inlet Valve?
    President:
  • 1,273 Answers
Hello Stacey, W/D here.
Yes, it can be a fill valve, usually called a solenoid valve. The easiest way to determine which one it is would be to close one of the water supply valves to the washer (one of the faucets at the wall). Close it when you have a slight level already in the washer, and watch the level. If the level continues to rise, the water is coming down the opened line, and that solenoid would need to be replaced.
Best regards, --W/D--
Posted on Apr 01, 2011
Water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Jun 04, 2010 | Danby DWM99W Top Load Washer
My whirlpool top load washer is leaking out the front side, no hoses are leaking.
Hello there:
Your washer can develop several types of leaks. I will post this solution in 2 seperate posts for you ok?
You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
May 26, 2010 | Whirlpool Washing Machines
There is water leaking from the bottom of the washing machine
couple of things to check, one make sure the drain hose is properly attached and no clogging. and also make sure all gakets are in good shape. and not worn out.
Nov 06, 2009 | Washing Machines
Water is coming from under the washing machine not out of the hoses, where could it come from?
There might be two possible reason for that.
it might be coming form the tub itself passing through the rubber seal of your plastic rotator(the big wheel inside the tub)
the other thing is in the junction of the hose the tub.
try to open the back of your washing macjine where you can get an access inside the wheel and the junction connector, from there you will the cause of the leackage. try to put some water while looking at so you can see where the water is coming out
Nov 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water is leaking out from the bottom
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for details.
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 26, 2009 | GE WBSR3140DW Top Load Washer
My LG wm model WD-1050F is out of use now because
The burning smell is coming from the burned out motor windings. The terrible internal sound is coming from a worn out bearing or friction caused by the motor rotor scraping the stator. These caused the motor windings to burn. Replace the motor then.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for deatils.
Oct 26, 2009 | LG Washing Machines
I'm getting water coming out of the seam on the left side between the top of the washer and the side panel. Is this hard or expensive to repair?
Oct 24, 2009 | Maytag Washing Machines
Washing machine leaks water as tank is filling up.
Hi
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Kenmore Washing Machines
Leaks water when filling up.
If the washer is leaking only during the fill and not all the time, the problem is most likely caused by a faulty air gap device, a leaking water inlet valve, or the tube. The air gap is a small device that keeps the washwater from being siphoned into the household water supply. It is usually located mid-way or at the end of the black hose that comes from the water inlet valve. Usually it is made of transluscent plastic. Look for leaks or cracks.
The tube is a rubber tube that runs between either the water inlet valve and either the air gap or the inlet spout. Check for leaks.
The water inlet spout - most washers have a plastic spout near the top of the main clothes tub that directs the flow of water into the tub. If the spout cracks or breaks free from it's mounting, it can cause leaks.
These are the things to look for if the washer is only leaking during fill. Hope this helps and best wishes.
Jul 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaking when wash starts
  • Oct 19, 2008 | Maytag MAH2400A Front Load Washer
    Washing Machines Logo
    161 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
