I can only suggest that you check and make sure all of the pins are straight and not bent over from trying to align the back plate with the back of the thermostat. Ive done it and its easy to do if you are not very carefull.
Check breaker. Was there a surge of electricity when the power went out. This may be a simple fix. Sounds like the breaker is tripped. Test the outlet with a light to see that power is to it.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
That depends....some on how you have it set up and some on how the building is responding to the unit....bottom line, I cannot give a definitive answer...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
The thermostat is a low voltage circuit (24 volts) most of the newer heating systems have a fuse for the low voltage controls. If you are having to re-set the high voltage circuit breaker, then you have something else wrong. When does the breaker trip? while its running or after it shuts off?
You have a bad capacitor about 20.oo part
