Question about Proview PA-19JK7 19 in. LCD Television
Remote control no longer functions so cannot access the source changing function.Is there anyway of overriding the remote using panel keys?
  • marionbagget Apr 01, 2011
    This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
    Step 1- Pull the batteries out of the remote and leave them out until Step 4.
    Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
    Step 3- If your remote has slide switches, you must move the switch to
    each position then repeat the button pushing in Step 2.
    (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
    Step 4- Put the batteries back into the remote, being very careful to install them correctly.
    New batteries should be used if you're not sure about the old ones.
    Step 5- Try the remote.
    Special Note:
    If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
    If you do then the problem might not be the remote but the sensor on the set.
    In the USA look at; www.remotes.com
    In the UK look at; http://www.espares.co.uk
    http://www.findremotes.com
Model LED2845A in setup I can't access the channel scan. I was able to access it when I first turned it on but can't any longer.
Check your current input. Use the Source or Input button to ensure that the TV is set to TV mode; there may be one on the TV in addition to the one on the remote. The icon may look like a rectangle with an arrow coming into the box from the left. The Channel Scan option is only available when the tuner is the active input. If you are using a universal remote, you may need to use a different code if the Input/Source button doesn't work. (Some universal remotes don't match this function at all. In that case, use the front panel button to change inputs.)
I can't find the model LED2845A TV. I see a Proscan PLED2845A and an RCA RLED2845A. The Source buttons are in different places on both the front panel and the remote on the two brands. Please add a comment with the brand of your TV if you would like to see where the buttons are for your model.
I hope this helps.
Oct 05, 2016 | Televison & Video
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Feb 07, 2013 | Apex Digital Televison & Video
How do i unlock a Gt 3215 apex tv? and where and how does the function button look like on a remote??
Hello
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Function buttona nd Menu buttons are the same or some remotes. I don't know whether you have the original remote of Apex or not. On original remote there is a function buttom marked as Function.
OK>
Jan 06, 2011 | Apex Digital GT3215 32" TV
Canon IR 6000 was donated, but can't use without control card. No access to card, can we override and reset so that it doesn't need one?
Additional Functions button> 2 and the 8 key at the same time >Additional Functions button again. Must be done fast. Another screen will come up. Touch Copier>Option>Coin> 0 > then ok at bottom right corner of display. 1 will change to 0. Now hit panel reset 3 times then power down machine.Then power on.
Sep 02, 2010 | Canon imageRUNNER 6000 Copier
I have a sharp 52". the remote will adjust the volume but, i can't change the channel. Help? Out of nowhere I could no longer change the channel. The Mrs is getting tired of standing next to the tv so I...
Sometimes, if certain remote control keys are used over and over again the rubber on the bottom of the buttons wears off onto the inside contacts, breaking the electrical connection. This is common on power and channel keys, especially. If you can get the remote opened up, you can clean the contacts with a cloth and it might help. Otherwise, it may be worth buying a universal remote. Good luck! Der Strom
Apr 05, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Streamium Remote control
Use new batteries for the remote.
May 31, 2008 | Audio Players & Recorders
Have a philips tv and a home theatre system but the remote off the surround system just changes the tv settings. Its kind of frustrating when I want to watch a dvd! Do I have to assign a freq?
When you press a function key on the remote control, not only does it change the function on the system (eg DISC, TUNER, TV etc) but it also changes the function on the remote.
However, if you change the function or source on the system, then only the system changes.
It sounds like you have changed the function on the system to DVD, but the remote is still set to TV. When in TV mode the remote will send Philips TV codes.
Press the DVD or DISC button on the remote.
May 10, 2008 | Televison & Video
Unlock apex tv model # AT2702
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the “Menu” key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight “Pass Code,” then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked . Hope this may help you
DON'T FORGET TO RATE:
Apr 17, 2008 | Apex Digital AT2702 27" TV
Proview PA-19JK7 19 in. LCD Television Logo
21 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
