Question about Polk Audio PSW202 Subwoofer
My sub woofer cracks & acts like the speaker is blown. Hooked it up to another source & the speaker is fine. What should I look at next?
    Brigadier General:
  • 8,546 Answers
So you're saying one source makes it crackle and another source doesn't. That suggest the sub is fine and we should examine the source and it's signal path. Please elaborate as much as you can on what it it/they are.
Posted on Apr 01, 2011
2009 Jeep Sahara sub woofer not working
if the wires are connected then you ether have a blown amp or sub. try hooking up a diff speaker to the wires if it works your sub is blown. if it doesnt your amp is blown
Mar 13, 2013 | Audio Players & Recorders
Sub woofer
You are suppose to hook subs up to a amp.
May 04, 2010 | Car Audio & Video
No sound from sub woofer
sub may be blown up, on protect, sub could be hooked up wrong. Did it work before and if so were all the wires hooked up the same? check to see if its being overloaded by blown speakers, check all speakers one by one, check your amp sub output with another speaker, I have had this problem form hooking up wrong.
Hope this helps...........
Apr 13, 2010 | Sony STR-DH500 A/V Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Sub-woofer malfunction
if the amp is going bad repair or replace, the sub you would probably have to replace, this would be the best fix. but check the amp also.good-luck!
Jul 12, 2008 | Logitech Z-5500 Computer Speakers
Bass in Car Gone, i don't know why!!!
Does the amplifier power up? If so, then check the voltage at the outputs...sounds like the outputs fried. Also, check the RCA cable to make sure it is getting a signal to the amplifier.
Jul 08, 2008 | Pioneer TS-W301R Car Subwoofer
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Polk Audio PSW202 Subwoofer Logo
300 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
