Question about Microwave Ovens
I have an Electric Griddle Modile PW-2365(cul). Where the heck can I get a drip tray for that? Larry Houghten Whitby, Ont.
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
Why is water dripping from inside the fridge around the rear light section?
In some Refrigerators there is tray below the freezer section and there is a small hole in the tray. Water dripping from the tray enters a hole below in the back and goes out to a chamber.
If the hole is covered with dirt or if you place something in the line between these holes, water will drip and collect in the bottom of the refrigerator.
Sep 12, 2011 | Microwave Ovens
I have a cv615 Miele Coffee Machine. The water reservoir was not inserted properly and water leaked into the bottom of the machine (drip tray). We got the Water System Fault message, so we removed the...
just use your hair drier to dry out the remaining water.Before doing anything remember to unplug the device.Remove the tray and other such attachments and let it to dry by itself for a day or two.this should solve the problem.never plug in the device till then.
regards.
plz. rate this
Jul 04, 2011 | Microwave Ovens
I need an LPH-2 thermostat power cord for electric griddle
Thank you for posting on FixYa. I might be able to help if I knew your make and model number.
Jun 03, 2011 | Microwave Ovens
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
I have a Viking Professional VGRT Gas 4 Burner + Griddle Cooktop. The griddle stopped working all together. The burners still all ignite and work fine. The griddle does not heat up. When we turn the...
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Jul 29, 2010 | Microwave Ovens
My mircowave oven just stop working.the lights are on all the electric stuff works,just on the inside where you put the food lights ont work and its not turning
I will bet you have blow a fuse. they are on the inside. this can be fixed at home. if you would like further help contact me . DFD
Apr 15, 2009 | Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
