Font and images print blurry, even after I performed a cleaning and alignment
  • biancadoyle_ Apr 01, 2011
    Hello!
    Thank you for your solution but how do I clean the optics and scanner lens?
    Genius:
  • 1,570 Answers
Hi
Try to clean manually first by rubbing the print head into a plain paper until ink flows and then run the print nozzle for 2 times.
If not, adjust the setting at the printing preferences or properties. Try to adjust the contrast to make better print out. Go to printer icon, right click mouse, choose printing preference or properties, and choose the contrast there to adjust the image resolution.
Post comment if you need more help.
Posted on Apr 01, 2011
  • Benjamin Jr Singson Apr 01, 2011
    Or use the BEST print quality option if there is. It is more likely a printing preference setting.
    Hi
    I did not mention to clean the optic scanner lens. No need to do that. Only if you have problem with scanning but not printing. I only suggest to go to printing preferences and adjust the contrast settion to give good darker print out. Please try it. Regards
  • 12,061 Answers
Http://www.techsupportforum.com/forums/f108/solved-blurry-images-and-fonts-198591.html
http://www.ehow.com/how_6813642_fix-images-internet-explorer-7.html
Repairs: On printouts bold fonts appear blurry, small fine print is either faded or missing.
Cause: Dirty optics and scanner lens.
Solution: Clean the optics and scanner lens (easier said than done!).
http://www.fixyourownprinter.com/forums/laser/2367
have a look above, it's relevant to your problem.
Cartridges won't align
The HP printer can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
1.On the front panel, press the Menu or Setup button (depending on the model).
1.Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
1.The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
If you go to HP website you can find more detailed information about alignment. Here is the link.
Dec 07, 2010 | HP PSC 950 All-In-One InkJet Printer
My canon mp470 prints blurry images. what to do?
Blurry images are produced due to poor functioning of the cartridges. This is mainly due to the fact that you either just re-filled the cartridges or you purchased poor cartridges. Buying new ones might be of help.
Secondly, ensure that you aligned the cartridge heads well. Go to your installed printer software to and perform a nozzle clean.
Dec 01, 2010 | Office Equipment & Supplies
HeLp! My HP CM2320nf MFP is printing blurry!
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
Apr 29, 2010 | HP Laserjet CM2320nf All-In-One Color...
Black catridge printing is not working
Hi Aravind,
Are you using a refill cartridge? It would be best to allign after installing the cartridges?
Since most cartridges today have electronic contacts on them, if you dirtied them before installing the cartridge, it is possible that this could affect the performance, you might want to take the cartridge out and clean the contacts with rubbing alcohol.
Also, the alignment of the print heads may need to be adjusted, my hp requires this to make sure the color and black line up properly, otherwise you get a blurry image.
Furthermore, if the problem is with the color cartridge and you are trying to print a page of black letters and the printer is set to use colors, it may try to print the black using all of the colors instead of using the black cartridge. So you may need to clean the color cartridge as well. Try looking at the printing properties and making sure black is selected when printing something that is only text and see if it does it correctly then.
Good Luck!
Jazerblue
Aug 24, 2009 | Epson Office Equipment & Supplies
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printing problem
stop putting in new cartridges in. You can go to the printer solution center and ask it to clean or fix streaks. you might also ask it to align to fix blurry edges. to get to the solution center
right click on the printer in your icon tray. You can also take a mildly damp soft cloth ans wipe out the cartridge carrier GENTLY. if these do not help you need ask it to correct the font.
Mar 14, 2008 | Dell 962 Photo All-In-One InkJet Printer
89 people viewed this question
jasbo
jasbo
